335i Feels slow going into second gear!!??
04-19-2007, 12:19 AM | #1 |
63
Rep 1,642
Anyone else notice this? the car feels like its hesitating a bit when switching into second gear with the manual trans. ..Anyone know what this is?
04-19-2007, 12:25 AM | #2 |
335
Rep 7,719
Can be a couple of things. If the clutch is hesitant, it's because of the clutch delay valve.
If you push the gas pedal, and feel a second delay in power, that's something else..which is normal. It delays the engine by a second or something of that nature. I read it on the board, but forgot all the details. |
04-19-2007, 01:17 AM | #4 | |
Autobahn Cruiser
25
Rep 272
04-19-2007, 07:16 AM | #5 |
STEVIL Empire
218
Rep 6,297
Only solution is to delete/modify CDV.
2007 E92 328i 6MT-Space Gray/Black Dakota/Gray Poplar w/heated seats-PCD 4/27/07 (SOLD)
2009 E90 328i xDrive 6AT-Space Gray/Oyster Dakota/Dark Burl Walnut w/ZPP,ZCW,Xenons-ED 4/17/09 - Redelivery 5/30/09 (SOLD) 2014 E84 xDrive28i 8AT-Alpine White/Black Nevada/Silver Matte w/ZMV,ZLP,494 - DD 3/14/14 (SOLD) |
04-19-2007, 07:25 AM | #6 |
22
Rep 579
Can You Elaborate Further? I Feel Like I Cant Launch The Car Without Revving Up To 4k Rpm And Letting The Clutch Off. Feels Like The Clutch Needs A Second To Pick Up Then The Car Moves. But Never Experienced It Going Into Second Gear.
04-19-2007, 09:00 AM | #7 |
149
Rep 1,254
I have a description for what mine does during very fast lift throttle 1-2 shifts.:
It falls flat on its face! Momentarily it's totally off boost even though I'm at WOT. I would like to attribute it to the DTC/DSC but it still happens with both disengaged. I do have 26 years of shifting experience and I do not have trouble shifting quickly. If I shift slightly less quickly I get no loss of boost. It does not like to be rushed into 2nd. All other gears for me are no problem. |
04-19-2007, 09:10 AM | #8 |
BK Employee of the month! / Moderator
636
Rep 15,795
I'm not sure if this is related but the other day when I took a test drive in the E90 335i w/ sports pack at the dealership, it seem to have turbo lag or at least I think it's turbo lag. I was going around 20mph and then I stomped on the gas (not too hard) and it took about 2 seconds before the car picked up. It might of been a second but I did feel it lag. I thought that the car was suppose to have torque at around 1400rpm. Hope there's nothing wrong, because my car is coming next month.
Btw, it was an automatic trans. |
04-19-2007, 09:13 AM | #9 | |
Rep 144
04-19-2007, 09:20 AM | #10 |
Too many Alex's, from now on, call me Beaufort
342
Rep 6,188
Naw, mine is removed and I feel what the OP is talking about. Theres a slight hesitation before the car gets power going. I think this might be the heavy dual mass flywheel in effect here. You dont feel this in the higher gears because you arent trying to shift as fast in those. Just my guess at least.
13 HD FatBob
17 A4 Glacier/Black 1st Edition/Pre+/Sport/EurocodeTMD/Racechip 16 S6 (gone),14 S6 (gone),14 S6 (gone),13 S6 (gone),10 S4 (gone) 07 335i(gone) |
04-19-2007, 09:47 AM | #11 |
Rep 337
According to all the car rags BMW has virtually eliminated most turbo lag but they say that it's there if you look for it. If you are on the edge of the RPMs where the torque curve is and stomp it you are likely going to find some lag. Having driven turbo SAABs that have more turbo lag I've kind of learned to "roll" onto the throttle as the boost increases. I'm sure the need to do this is less with the BMW and the smaller, fast spooling twin turbos, but at low RPMS this is probably still necessary to avoid the on/off switch feel of the turbos spinning up. Most people who drive turbos figure out over time to keep the RPMs above a certain limit but that's not as necessary with the 335i I don't think. Of course this is all speculation because, well, my car is somewhere on the Atlantic right now . . .
E90 335i: TiAg, black leather, burl walnut, 6MT, Sport, Premium, Cold Weather, PDC, Sirius, Comfort Access, Nav
ED: 3/30/2007 Redelivered! 5/15/2007. |
04-19-2007, 10:02 AM | #12 |
12
Rep 383
I'm a little confused. I know the car hits max torque at 1400 rpm, but isn't that a function of engine load? So if you're cruising around at 20 mph in 3rd gear (assumption) and you stomp on the gas, the AT will downshift and the turbos will build boost. But if you were in already in a lower gear, the engine would have been loaded differently and therefore you would experience less delay. Is this correct?
04-19-2007, 10:56 AM | #14 |
12
Rep 383
04-19-2007, 12:23 PM | #15 | |
Rep 337
04-19-2007, 01:08 PM | #16 |
Klaatu Barada Nikto
28
Rep 1,169
04-19-2007, 02:05 PM | #17 |
63
Rep 1,642
Its definitely not the dsc, I turned that off, no difference, its also not turbo lag..the car has very little if any turbo lag. Like clem said it falls flat on its face unless revved up to 6-6.5k in first gear, then the tires will chirp a bit in second and keep on going. Anything less than that it feels almost like power delivery just stopped..I keep expecting it to slam me into second but it doesnt!
04-19-2007, 05:36 PM | #18 |
Drives Smart
54
Rep 2,393
In an auto 335 turned off DTC i think and was going 20 in 2nd pretty sure and tires were starting to break loose so I dont think its lag..
04-21-2007, 05:46 PM | #19 |
63
Rep 1,642
maybe my car is just slow?? If I am going 20-25 mph in
1st and push the pedal to the floor the tires dont break loose at all..even with dsc completely off.. Last edited by jcarlucci1; 04-22-2007 at 02:23 PM.. |
