Speaking of lights, did you notice?
04-18-2007, 10:43 AM | #1 |
Too many Alex's, from now on, call me Beaufort
342
Rep 6,188
Ok, so I was at a red light the other night and did the light flashy thing to make it change(here in NJ a lot of lights have the sensors).
So I noticed that when I was flashing, it seemed like it wasnt as bright as Id expected. Seemed more like only one light was working and I got nervous that a light was out already. When I got home I tested my lights against my garage door. You can clearly see the HID light of the regular lights. When you pull back on the turn stalk you use the "flash to pass" feature. Normally, this uses the brights. However, I noticed it wasnt an HID light(and I have bi-xenons). The "flash to pass" uses the DRL lights apparently. Then I pushed the stalk forward to turn the brights ON. Now you can clearly see two HID lamps on the garage. Anyway, I thought this was interesting that they used DRL's to flash so you dont blind people with HID flashes.
13 HD FatBob
17 A4 Glacier/Black 1st Edition/Pre+/Sport/EurocodeTMD/Racechip 16 S6 (gone),14 S6 (gone),14 S6 (gone),13 S6 (gone),10 S4 (gone) 07 335i(gone) |
04-18-2007, 10:45 AM | #2 |
Moderator
318
Rep 17,767
Drives: F36 428i,E90 328i, E85 Z4 3.0i
Wait you have flash-to-activate traffic stop lights in NJ? I think I missed something here...that's new to me.
They use the halogens for the flash-to-pass as it takes less time to activate versus the xenons. It also limits wear on the xenons 'shutters' I suppose.
Official DC Metro Registry - Current, New & Prospective Area Members Roll Call! |
04-18-2007, 10:51 AM | #3 |
342
Rep 6,188
They've been around for a while. Not all stoplights have them but a lot do. If you flash at a certain distance a few times, it will change the light to green.
13 HD FatBob
04-18-2007, 11:31 AM | #4 |
1312
Rep 10,185
To "flash" the E90 uses the inner lights, which are halogens
If it used the Xenons to "flash" it would blind people
BMW if you are reading, I need a job, Please. |
04-18-2007, 11:32 AM | #5 | |
383
Rep 7,952
04-18-2007, 01:49 PM | #6 |
342
Rep 6,188
I know what youre talking about. You can see them buried in the pavement. Those are different though and you CAN make a difference if youre not over them but flash your lights.
13 HD FatBob
04-18-2007, 01:50 PM | #7 |
Moderator
318
Rep 17,767
Isn't the ground sensors feeding off weight and metallic content of vehicle?
04-18-2007, 01:50 PM | #8 |
342
Rep 6,188
Not weight but they are magnetic. When riding a motorcycle, somtimes you need to tip it a bit to trigger the sensors.
13 HD FatBob
04-18-2007, 02:11 PM | #9 |
Moderator
132
Rep 6,775
Drives: TiAg E92 335
The E46 with Bi-Xenons was the same way. I always thought that it was done like that because when your headlights are off during the day, you need to be able to flash someone so it would use your halogens. If it were to use your xenons it would put a lot more wear on them from having them turn on and off every time you pulled the lever back a few times to flash someone. If you really want to blind someone, just push it forward.
-Michael.
Berlina Black S2000 CR is now in the garage l 19" Rial Daytona Race l KW V2 l Eisenhaus Race Exhaust l |
04-18-2007, 02:13 PM | #10 |
8
Rep 196
I tested my e92 and flashed the lights in my garage and the xenons flash not the halogens. The halogens only work when i'm making a left or right turn, but they are never on at the same time unless i'm in reverse.
Le Mans Blue
15% All-around Tint 335i Coupe - Fully Loaded with M-Sport package Light Grey Interior, Grey poplar, black headliner 194 19"Black powder coated polished. |
04-18-2007, 02:14 PM | #11 |
8
Rep 196
Maybe if my lights were off and I tried to flash then it would flash the halogens.
Le Mans Blue
04-18-2007, 02:51 PM | #12 | |
2751
Rep 6,759
And the definitive reason for this has nothing to do with blinding incoming traffic, as you will do this with a high beam pattern regardless of the light emmitting technology. Nor does it have to do with abusing the Xenon lights, since Xenon bulbs tend to last far longer than Halogens, plus the fact that flashing is a rarely used feature. It has everything to do with how quickly the Xenons can respond to being turned on/off - it can take a second or more, which is unacceptable for the flashing functionality. Even if the lights were on low beam, triggering the mechanical shutter for the high beam pattern still takes too long a time. Because manufacturers want to keep this flashing functionality, they are currently unable to get rid of the halogens. IMO the only way to do that in the future is via LED lighting. |
04-18-2007, 03:26 PM | #13 |
Smiling politely
165
Rep 7,931
I can't believe nobody has posted this link yet:
http://www.snopes.com/autos/law/strobe.asp Claim: Flashing your car's high beams at a traffic signal will cause it to change from red to green more quickly. Status: False.
E90 330i Black Sapphire 6MT | 991.1 C4 Platinum Silver 7MT
04-18-2007, 03:27 PM | #14 |
8
Rep 196
If the headlights are already on and I push or pull the stalk the xenons flash regardless of which way the stalk is positioned.
Le Mans Blue
04-18-2007, 03:32 PM | #15 |
2751
Rep 6,759
04-18-2007, 03:34 PM | #16 |
8
Rep 196
Maybe I wasn't too clear in my post. I wasn't asking, I was stating that happens in my car.
Le Mans Blue
04-18-2007, 03:37 PM | #17 |
11
Rep 613
04-18-2007, 03:40 PM | #18 | |
2751
Rep 6,759
I had just gone downstairs to the loaner E90 328xi I currently drive and it was working the way I'd described it. But never tried it on a Coupe... |
04-18-2007, 03:43 PM | #19 | |
571
Rep 7,519
Drives: 2009 E90 335i MT
I had an alarm system on a previous car that had two glass vials with a pea-sized ball of mercury inside. Each vial was wrapped with a copper coil and they were oriented at 90° to each other. When the alarm was set, a small current was passed through the coil. If the car was jarred, the mercury would jiggle. Depending upon how much it jiggled the impedence of the coil changed. If the change was more than the sensitivity level of the alarm the alarm would activate. Works the same as the road sensors. You might also have noticed that there are the cutouts in the middle of the lanes of some highways. These function the same way but are used for detecting traffic flow levels.
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7 European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269 |
04-18-2007, 03:47 PM | #20 |
8
Rep 196
yeah so we were both right.... just about different cars
Le Mans Blue
04-18-2007, 03:52 PM | #21 | |
571
Rep 7,519
04-18-2007, 03:52 PM | #22 | |
342
Rep 6,188
e90 335: pull stalk, halogen DRL's come on
13 HD FatBob
