where is the xenon tinge?
04-18-2007, 01:29 AM | #1 |
46
Rep 558
does anybody know y the 335 xenons dont look as blue as they should? or is it just my e 92 xenons that doesn't have a bluish tinge to it? evrytime i turn it on it has a nice shade of blue to it but doesn't stay for long...?
04-18-2007, 01:55 AM | #2 |
your average JAMF
3101
Rep 4,094
Drives: '21 M2 Comp, '19 Golf R
Because blue is not good for vision. If you want to look "cool", there are bulbs with higher color temperature, which WILL reduce the quality of your illumination, but will make you look "cool".. if having lights that are more dangerous than stock is what floats your boat.
'21 M2 Comp
'19 Golf R |
04-18-2007, 03:34 AM | #3 |
Those Crazy Germans
Rep 122
How old is your car? Xenons require a break in period before they get the most colorful. I believe the standard bulbs are 4100k which is the optimum for white light output. I believe its after 160 hours that your bulbs begin their colorshift and you start to get more color out of your bulbs. There are ways to mod your lights so that you can get more color but it would require you to take apart your headlight assemblies. For instance you can bend your cutoff shield a bit to increase the color of your xenons but it makes your cutoff less sharp. You can add washers to the contact points of your xenon housings to create more color but once again you lose the sharpness of the cutoff. Color also has to do with the type of projector that is used along with the type of lense that is used in the projector as well. Newer cars, to conform with DOT regulations now mostly use fresnelled lenses or basically lesnses that are not clear. Some of them have a metal bar in it, some others have grooves in it... all designed to cut the amount of color and fliker that the xenons produce. Right now probably the best projector lense and assembly on the roads are the old e46 lenses, the TSX lenses or the S2000 lenses.
In short there are ways to get more color out of your xenons but if your car is pretty new I'd give it a while before you try to get more color out of your lights. Give it some time and your lights will get more colorful on their own. Heres a pic of what my lights look like today. I just picked up my car maybe 15 hours ago and already took some pics of the cutoff. As you can see there is definitly color there but you can barely see it if you're looking directly at the lights. I'll give it a few months and then see if I need to do any modifications. |
04-18-2007, 05:57 AM | #4 | |
1705
Rep 14,829
04-18-2007, 07:43 AM | #5 |
13
Rep 548
Headlights aren't supposed to be blue. Don't forget to rice out your turn signals with clear bulbs while you're at it.
04-18-2007, 07:45 AM | #6 |
76
Rep 2,104
SaaS - The world of tomorrow is already here...www.saaschronicles.com |
04-18-2007, 08:24 AM | #7 | |
Smiling politely
165
Rep 7,931
Besides, go for purple. Much cooler than blue.
E90 330i Black Sapphire 6MT | 991.1 C4 Platinum Silver 7MT
04-18-2007, 08:43 AM | #8 |
pull my finger to get your kinder® surprise
148
Rep 10,455
I love Ting too man, it's delicous and refreshing
04-18-2007, 11:09 AM | #9 |
Rep 38
Color Temp above 4150k will not help you on wet roads. Yes your lights will be bright, but useless. Too me that defeat the purpose of xenon projector headlights.
Just leave it alone and save your money. |
04-18-2007, 12:01 PM | #10 |
My car is for sale
7
Rep 239
How do you figure?
2008 E90 335i: Alpine White | Terra | Burl | Sport | Premium | Nav | iPod | Heated Seats - Sold
2004 E46 325ci: | Titanium Silver | Gray | Burl | Sport | 5sp - Sold |
04-18-2007, 12:06 PM | #11 |
Those Crazy Germans
Rep 122
04-18-2007, 12:26 PM | #12 |
Rep 38
Just my observation from trying so many GOD DAMN bulbs. I spent alot of $$ on my previous car's xenons and I found 4000K to 4150K was the perfect intensity and Luminance on a dark, wet road. At higher temp, I notice by observation a loss in my Luminance onto the road surface. Very minor, but a loss by comparison. Since my concern is for visibility in all road conditions, I stick to 4000K to 4150K. I probably should not have use the word "useless" in my last post.
04-18-2007, 03:54 PM | #13 |
Rep 81
There has been a recent move by the manufacturers of HID systems (Hella, Piaa, Phillips, etc.) toward making HID's not as blue. As most of you know, 4000k is the best because it most closely resembles natural white light. Anything deviating from this color temp, will reduce the lumens or light output.
Inside the HID projector assemblies, there is a metal part that covers roughly half of the lens. This piece is called the cut off shield. If you move the shield slightly closer to the focal point of the reflector lens, the prism effect from the projector will yield you a bluish color at or near the cut off line. It will tend toward the redish color if you move the cut off shield away from the focal point of the reflector lens. The cut off shield is the part that provides that distinct cut off line; slightly lower on the driver's side and slightly higher on the passenger side. (The cut off shield for UK cars are exactly opposite.) This cut off shield geometry is magnified 1000x times when projected through the lens, so modification to the cut off shield must be highly accurate. As a cheap experiment, (if you can manage to pull it off) try pushing the cut off shield toward the focal point of the lens, aft direction of the car, and just the effedts of the pressure of your finger on the shield will change the cut off color to a much more bluish tint. Most Acura's and Honda's still use the old blue cut off shield while BMW has moved to a whiter one. The adjustment of the color by the way of manupulating the cut off shield distance to the focal point has the added effect of "bleeding" the razor sharp cut off on late model cars as well. A razor sharp cut off may look cool but it is actually more dangerous on the road. I disagree that S2k and TSX's are the best due to their sharp cut off. A bleeding cut off partially illuminates elevated road signs without blinding on coming traffic. A razor sharp cut off has no benefits whatsoever except for looking cool when facing a white wall. Just as a side note, on bi-xenon's, when you turn on the high beams, the only thing that is happening is that the cut off shield slides down to reveal the entire reflecting surface. The low beams are just the bottom half, (or top half depending on how you look at it because optics switch everything top to bottom) of the projector light. The rest is just being covered by the shield, there is nothing else that turns on(bulb wise) when the highbeams are engaged. Xenon bulbs will tend to be more whiter/bluer over age due to the degrading halide crystals in the bulbs, however, it is not a noticible difference. |
04-18-2007, 10:54 PM | #15 |
8
Rep 196
I have also observed that the e92 headlights point downward more than other cars with xenon headlights. On the 5's, the headlights point at a slighty upward position. Because of this, it seems that almost all headlights are "brighter" than the e92 headlights.
Le Mans Blue
15% All-around Tint 335i Coupe - Fully Loaded with M-Sport package Light Grey Interior, Grey poplar, black headliner 194 19"Black powder coated polished. |
04-18-2007, 10:58 PM | #16 | |
BMW, can I have some LSD please?
88
Rep 1,591
2006 330i | TiAg | Black | Al | 6MT | Sports Package | Logic 7 retired
2008 335i | AW | Black | Al | 6MT | Sports Package | Logic 7 retired 2013 328xi | Red | Gray | Al | 8AT | Sports Line | Premium | Executive | Heat Pkg retired 2017 340i xDrive | Estoril | Black | Al | 8AT | M Package |
04-18-2007, 11:01 PM | #17 |
88
Rep 1,591
Aaaahh! This is where you need to look at the DIY for raising your lights' aim, the thread which was started by yours truly. :rocks:
04-18-2007, 11:02 PM | #18 |
8
Rep 196
Oh didn't know that you could change the aim on auto leveling headlights!!! Does it mess with that feature to where they don't auto level anymore?
Le Mans Blue
04-18-2007, 11:09 PM | #19 | |
88
Rep 1,591
Here's the link: http://www.e90post.com/forums/showth...ight=headlight Just be careful not to aim them too high!
04-18-2007, 11:19 PM | #20 |
your average JAMF
3101
Rep 4,094
Awesome meal consumed last year at Scilly Cay off Anguilla (both HIGHLY recommended if you're searching for a Caribbean destination). A bottle of Ting to wash it down was the obvious choice. :rocks:
'21 M2 Comp
'19 Golf R |
04-19-2007, 07:51 AM | #21 |
4972
Rep 10,200
Drives: 2024 Golf R / 2022 718 Spyder
This thread is funny...
The stocks are fine by me--you want a little more "blue", spend $30 and change your angel eyes out. Then you get the tinge you are looking for without sacrificing the light quality of the Xenons.
Past rides: 2016 981 BGTS, 2020 MINI JCW, 2017 F80, 2015 981 CS, 2014 F22 235, 2011 E82 135, 2008 E82 135, 2007 E92 328, 2007 E92 328 (My lady drives an OG M2. So does my dad)
