Just finished MS-8 Install.. fried MS-8?
08-06-2011, 10:47 PM | #1 |
9
Rep 184
I just finished installing my MS-8 & amplifiers Here is the setup:
Channels: 1 --> RCA --> AMP --> FL 2 --> RCA --> AMP --> FR 3 --> RCA --> AMP --> FLW 4 --> RCA --> AMP --> FRW 5 --> Center 6 --> Rear Left in parallel (sides and deck) 7 --> Rear Right in parallel (sides and deck) 8 --> RCA --> AMP --> Sub Turned everything on and things powered up fine. Started doing the setup and got all the channels and crossovers done. Went into the audio diagnostic and the center & rears do not output anything (channels 5-6-7). These are the only speakers being powered by the MS-8's amp. There is also a loud buzzing noise when everything is powered up, and the amps pop really bad when they receive the initial signal. I double checked everything to find out the MS-8 is blazing hot. I couldn't even touch it. This is just after running the setup, which leads me to believe something is very wrong. I disconnected the output plug and verified the 3 channels were connected right and left it disconnected to try to setup the system with fronts and subs only using only RCA outputs. Same thing, but this time only my sub outputs any sound in diagnostic mode. Fronts did not put out a thing. Buzzing is still there and the MS-8 is hot as can be. Anything I could be doing wrong causing this ? I've worked in car audio in the past and I am fairly competent when it comes to hooking up audio systems.
2009 e92 335i 6spd :: Black Sapphire Metallic :: Coral Red :: Work Gnosis GS4 Wheels (20x8.5+32/20x9.5+35) :: Bronze Rays Lug Nuts :: AngeliBright v3 :: PROcede v4 :: Injen DCI :: Clutch Stop :: B&G S2 Sport Springs :: Matte Black Kidney Grilles :: Tinted Taillights :: Escort Passport 9500ix :: Samsung S1 160GB HDD
08-06-2011, 11:48 PM | #2 |
9
Rep 184
Ran through everything again with the output harness disconnected. Noise and popping is gone, but the woofers and sub outputs are EXTREMELY quiet. Overall volume is very low. I had the gains set to 1/4 during calibration, turning them all the way up after calibration didnt help much. I ran the sweeps at -40 and -20db and neither seemed to do well.
advice ? MS-8 is still running hot.
08-07-2011, 12:21 AM | #3 |
687
Rep 6,845
Drives: 2018 Audi RS5 coupe
What setup do you have originally?
If you have 2 ohm speakers and you're running them in parallel That's a 1 ohm load Which the ms-8 can NOT handle Do you have a multi meter? Measure the resistance on the wires going to the speakers powered by the ms-8 Thats a common fault if the amp gets very hot Don't ask me how I know
08-07-2011, 12:24 AM | #4 |
687
Rep 6,845
Also the with the rcas unplugged
So just the speakers powered by the ms-8 Does it still get hot? If that doesn't work then you'll have to disconnect everything And hook them up one by one till you figure out which speaker/output is causing the problem
08-07-2011, 08:17 AM | #5 |
300
Rep 3,969
I've had my L7 sides and rears (2 ohm) hooked up in parallel for over a year now with zero ill effects. Still, if I had to do it over again I would run them in series, since there really is no disadvantage doing that and it gives the amp a safer load.
If the MS-8 runs that hot during set-up, I would suggest it is fried. Just make sure though that you are not letting the sun shine on it, otherwise it will get that hot in a millisecond!
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
08-07-2011, 08:46 AM | #6 | |
2295
Rep 13,001
08-07-2011, 08:49 AM | #7 |
9
Rep 184
OK.. Buzzing is gone. I don't have the rears or center hooked up so I can at least test the other things. I ran through the setup with the amp gains set to 1/4. The woofers and sub are so quiet I cannot even hear them after setup without cranking the volume and gains to max. Even then they are not very audible.
08-07-2011, 09:39 AM | #8 |
9
Rep 184
Ran through again.. Got the levels up by running the sweeps at 3/4 amp gains and -6db on the ms-8.
During my front 2-way setup I never see the option for a hi-pass filter? Only a x-over option I set to 150db. Where do I set the high pass for the mids?
08-07-2011, 10:24 AM | #9 |
300
Rep 3,969
If you're sweeping with -6dB and 3/4 gain on amps and the sweeps are not destroying your speakers (or ears)... then you have a faulty unit.
08-07-2011, 11:48 AM | #10 |
9
Rep 184
I disconnected the inputs to the MS-8 and it is still feeding low level noise to the amps. Sub sits there are vibrates with nothing playing. This is depressing.
08-07-2011, 11:49 AM | #11 |
687
Rep 6,845
Don't be depressed
Just send it back for a brand new one
08-07-2011, 01:23 PM | #12 |
9
Rep 184
I might be screwed. I picked it up off ebay NIB, but the shop has a 7-day return policy. I contacted them stating the problems with the unit. If they will not take it I would have to go through JBL? Is that an easy process?
08-07-2011, 02:45 PM | #13 |
687
Rep 6,845
I know a few people who had theirs exchanged by JBL
And they were either bought off eBay or even purchased used Try with the eBay seller first If not I think if you paid by paypal, you can mail it back and paypal issues you a full refund
