Aftermarket Sirius Radio
08-04-2011, 09:16 AM | #1 |
21
Rep 94
My car is satellite ready, but it doesn't have the module.
I talked to dealer and they said it will cost me $700 plus tax to install the module and reprogram the computer. Any suggestion for aftermarket satellite receivers? Thanks! |
08-04-2011, 09:25 AM | #2 |
110
Rep 2,017
Drives: AW 07 e92 335i + AW 11 X5 35d
Your dealer is killing you!
2011 models should already have the satellite radio hardware in place. It just needs to software activated. I believe you can buy just the SW ID code for about $200ish from tischer and program it in yourself with a cable. If you go to the BMWUSA.com website and look under accessories -> entertainment, you will find the sirius xm option for post 09/2010 cars to be $375. Without Nav http://www.shopbmwusa.com/ProductDet...CClistInterior With Nav http://www.shopbmwusa.com/ProductDet...CClistInterior |
08-04-2011, 09:35 AM | #3 | |
21
Rep 94
And the link you sent me in previous post says: the car should be with satellite radio prep (SA693), How may I know that mine has that? the only visible thing is the satellite antenna over my trunk. |
08-04-2011, 09:41 AM | #4 | |
110
Rep 2,017
Best way to know is to ask your dealer to lookup your VIN to see if you have that option. Or I believe you can look at your monroney window sticker. |
08-04-2011, 10:02 AM | #5 | |
21
Rep 94
Meanwhile, I hope someone helps me with the programming tips, but I guess eventually it needs to be done by the dealer to keep the car's warranty valid! |
08-11-2011, 11:18 AM | #6 |
21
Rep 94
So finally I decided to go with SIRIUS STILETTO 2 which is a portable satellite radio and I can buy it online for $230, is it a good choice, I guess I can fit it inside the middle compartment with a lighter charger and AUX cable.
any comments/advices on that? |
08-11-2011, 12:27 PM | #7 |
54
Rep 199
Drives: M235i xdrive
There should be a pink antenna connection in the trunk of your car in the center storage compartment. I installed my aftermarket sirius radio into that plug. Then ran the wires to the center console for aux and cig lighter then ran wires to mount my sirius in the ashtray. There are a few post on here showing that install and the website to order the L shaped cable that will connect from the pink in the trunk to the sirius radio. if you cant find it let me know and I'll pull up the order form when i get home. It was a very easy install took less than 30 minutes to run the wire on passenger foot well into console for total install.
SOLD: 2015 BMW M235i Glacier Silver on Coral Red
35% tints, Gloss Black Roof, AFE Magnum Force Stage 2 Intake, AFE Power Scorcher, P3 Vent Gauge and Fabspeed muffler delete. |
08-11-2011, 12:42 PM | #8 | |
21
Rep 94
08-11-2011, 02:45 PM | #9 | |
54
Rep 199
Im using the sirius starmate 5. the pink plug in the trunk of your car is a direct connect to the antenna of your car so there will be no noise or interference. just plug one end to that pink plug the other to the sirius radio in the front of your car. when running the wire to the front of your car make sure you run it on the passenger side sill then under your passenger seat there is a seam in the carpet you can tuck it in there and bring it right into the console where the aux port and lighter port is then threw to the ashtray or any other mounting area. I'll send you tonight the website for the cable and if i have instructions with pictures as well.
08-11-2011, 03:20 PM | #12 |
54
Rep 199
mine is a 2008 and it has it. i could be wrong but I think all E9x bmws are prewired. A few of my friends have E9x and all of their cars have the plug.
08-11-2011, 03:55 PM | #13 |
21
Rep 94
08-11-2011, 04:24 PM | #14 |
253
Rep 7,089
Drives: '06 AW 330xi
Do you have an iPhone? I think you can get a sirius app. Maybe I'm confusing myself with something else.
08-11-2011, 06:40 PM | #15 |
54
Rep 199
cable needed to connect plug in trunk to aftermarket sirius. you do not need to go to bmw to get it turned on (coded). you are using the prewired plug in trunk as the antenna connection.
cable link: http://www.cdint.com/catalog/advance...=sb9sbj-174-16 plug the cable in above link into pink plug and run on passenger side of car to the aftermarket sirius radio in front of your car. the 90 degree angle plug goes into the sirius radio. here is a picture of the pink plug that is in the center of the trunk under the trunk matt as well as the final install picture.
35% tints, Gloss Black Roof, AFE Magnum Force Stage 2 Intake, AFE Power Scorcher, P3 Vent Gauge and Fabspeed muffler delete. Last edited by Gilda G; 08-11-2011 at 07:18 PM.. |
08-11-2011, 08:47 PM | #16 |
21
Rep 94
08-11-2011, 08:48 PM | #17 | |
21
Rep 94
08-12-2011, 08:53 AM | #18 | |
54
Rep 199
it worked for me so strange go this route then www.cdint.com under catalog search type in sb9sbj-174-16 I just did it and the cable came up.
