Resetting the TPMS
04-16-2007, 10:43 PM | #1 |
18
Rep 216
Resetting the TPMS
Okay, earlier today I decided to reset the tpms system and for some reason its still "resetting." I was wondering what experiences others have had in resetting the suckers and if there was some "secret" involved.
I still have the stock tire set up and thought a simple reset would just test if my tpms are active and functional. Right now there is that annoying yellow flat tire light and the "tpms resetting" in my nav. I have idrive. IF anone can help me out with this id greatly appreciate it. Tried the search but no info on my dilema. Thanks |
04-16-2007, 10:51 PM | #2 |
11
Rep 371
Drives: 645Ci
air up your tires, reset it and drive. it should get back to normal after a few minutes of driving. it has to be driven to re adjust.
Current Ride: 04' 645Ci
Retired Rides: 07' e92 04' e46 |
04-17-2007, 06:20 AM | #3 |
418
Rep 12,276
How far have you driven since you reset it? The system can take several miles of driving to complete the reset procedure. I doubt there is any problem, but if it is still resetting after your next drive of a least a few miles then call your SA and ask about it.
I think it is bad luck to be superstitious |
04-17-2007, 08:02 AM | #5 |
39
Rep 1,349
It should only take a few hundred feet to reset. I know when I first reset the system... I really wasn't resetting the system. You have to push the button once to get the checkmark next to reset.. then... push and hold while the little clock spins. Hold till the clock stops spinning and the little window shows your temp, etc again. Driving down the block always resets the system for me. I've never had it takes "miles". Please correct me if I'm misinformed.
Any man who can drive safely while kissing a pretty girl is simply not giving the kiss the attention it deserves. ~Albert Einstein
04-17-2007, 08:56 AM | #6 |
133
Rep 4,764
What do you do if you don't have idrive?
04-17-2007, 09:10 AM | #7 | |
418
Rep 12,276
04-17-2007, 10:18 PM | #9 |
Rep 57
04-18-2007, 05:24 AM | #10 |
133
Rep 4,764
Thanks for the answer!
