2011 base audio wire tap / install
08-03-2011, 01:58 AM | #1 |
57
Rep 271
Drives: 2015 X5 50i, 2015 Macan Turbo
Hi Guys,
Only found the wire diagrams for the L7 and Hi Fi. What are the front channel wire colors from the base audio in the coupe? Can I tap them under the floor trim by the seat where the wires go to the subs - to connect my processor and amp? Dont want to pull the HU from the dash. Thanks... |
08-08-2011, 02:01 PM | #2 |
Ohhai
19
Rep 134
I just did this, yes you can. If you just pull the carpet up a little towards the front of the car you will see which wires run towards the door, those power the midrange in the door. The others stop at the woofer. Sorry I do not remember the colors. The two left wires are positive for the sub and for the midrange, and the two respective right side wires in the sub connector are negative for the sub and midrange. Sorry if that's unclear.
08-08-2011, 08:04 PM | #4 |
57
Rep 271
thank you guys!!!!!
This is so helpful. |
