Reset Red Flat Tire Warning
08-02-2011, 08:39 AM | #1 |
Rep 7
I am new to owning a BMW (about a year now) and I am not used to a car being so smart. When I put winter wheels on this last winter, I had the red flat tire warning go off and I couldn't ever get it to reset. The wheels came off of a 2005 BMW 3-series (e46) and the BMW dealership said that there is a possibility that the flat tire monitor in the wheels is not compatible with my e90. They said I could either live with the warning lamp all winter or pay to have compatible flat tire monitors installed for $800. I opted for the first choice.
When I put my summer wheels back on the flat tire warning stayed on and I couldn't reset it. I took it in for service and BMW found that I had a tire with a plug in it and the plug was drying out and leaking. BMW filled the tire and reset the warning indicator. It came on again and I took it to a tire shop. They found that there was another hole in the same tire so I had that tire replaced and they reset the warning again. Everything has been just fine since then (about two months). This morning the red flat tire warning came on again and I stopped and checked the pressure in all my tires. The rears are right at 35 psi and the fronts were a little over 30 (this is after driving 3 miles) and the temperature is about 80 degrees. I plan on checking again this afternoon after the car hasn't been driving for awhile to see if the pressure drops. The problem I am having is that I cannot get this to reset. I am not talking about the yellow indicator light that allows you to initialize (INIT) the system. I have been able to do that in the past. This is the red light that says reset when you go through the controls. I have read the manual and followed it to a "T" and the thing never resets. I don't know how the garages got this to reset. Maybe they had to hook it up to a computer to do so? Has anybody else had this problem? I am worried that I need a new flat tire monitoring system and worried about how much that would cost. Sorry for the long post, does anybody have any suggestions? |
08-02-2011, 11:02 AM | #3 |
115
Rep 1,544
Drives: '22 i4 M50
Hope you get it sorted out...just recently, this past week, my yellow and red TPM indicator has been going off, even though there are no leaks in my tires and they are all pumped with a good amount of air. But it's been coming on and off quite often these past 3 days.
2022 i4 M50, Dravit Grey. fully loaded minus the carbon fiber bits and 20" wheel package
2007 E92 335i, 6MT, Sparking Graphite, ZPP, ZSP, Nav, Logic7 (Sold) |
08-02-2011, 11:24 AM | #5 |
189
Rep 5,046
Thumb through the options on the stalk. When you get to reset click the button once and a little box will appear. Then hold the bottom down for a few seconds and the box will check it self. Profit.
08-03-2011, 08:48 AM | #6 |
Rep 7
Thanks, I will try this!
I don't think I have ever tried this in this fashion. I will be sure I try this before I take it anywhere. Does anybody think that this is something that needs fixed? My car no longer has run flat tires, it just has high-performance all weather tires that are Bridgestone Potenzas. Does anybody have any idea how much a repair like this will cost? I really don't want to take it to the BMW dealership because they really over charge! They charge around $125 just to diagnose it!
08-03-2011, 09:07 AM | #7 |
Rep 7
Would this cause the red TPM to go off?
I was reading about wheel speed sensors and it seems like I should have three lights coming on if this were the case (an ABS light, an amber BRAKE light, and a triangular "traction lost" icon). I only have the little red tire icon with an exclamation point. Can TPM go bad and go off and on again? If this is the case, is this something I can repair myself or will a BMW dealership have to do it?
08-04-2011, 08:18 AM | #9 | |
Rep 7
I've tried everything
If I go through the menu options and click the button it just sits on the word "reset" for a few seconds and then goes back to the red exclamation point. I tried hitting the BC button and then clicking the options down and up and nothing said "resetting" like I would have expected or like I have read on other forums. This one really has me thrown for a loop. I have always had to have the garage do this for me. I just really can't stand the thought of paying BMW $125 just to tell me that I need a new flat tire monitor and then charge me whatever that costs plus labor. |
08-04-2011, 10:43 PM | #10 | |
173
Rep 3,415
08-05-2011, 09:34 AM | #11 |
Rep 7
I figured it out!
I figured out how to reset this warning yesterday. I think this is what one of the answers was alluding to previously. I had to scroll up to the error and push the BC button once then I pushed it again and held it down for about five seconds and a little check mark appeared inside a box. I drove off and so far everything is fine. I am still taking my car to a local garage to test the FTMs to make sure they are functioning properly tomorrow. It seems odd that this would come on in the summer when tire pressure should be at its highest.
08-05-2011, 07:19 PM | #12 | |
189
Rep 5,046
07-17-2014, 02:56 PM | #13 |
Rep 1
Drives: 2007 328i bmw
red abs light (!) kinda looks like that
so mine just came on and what is the BC? cause i have done it through the manual and that didnt work and i called bmw and they said its the wheel speed sensor ! so what another way to try to reset it?
Tags |
2006 bmw 325i, flat tire monitor, reset, warning lights, wheels and tires |
