TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > TPMS disable
      07-31-2011, 07:13 PM   #1
pnosker
ti fan
67
Drives: 14 12C | 17 X5 50i | 19 M2C
TPMS disable
Background: 2008 135i
Tried changing VO by removing $2VB, removed TPMS fuse
TPMS light is still on!! What do I have to do?
Thanks in advance for your help!
      07-31-2011, 07:25 PM   #2
Hooy
Hooy's Avatar
205
Drives: E92 328i, E92 M3
2008 E92 328  [5.00]
Just buy TPMS and pay the tire dismount/remount fee??
      07-31-2011, 09:46 PM   #3
pnosker
ti fan
67
I could, but I have 4 sets of wheels that go on for different occasions (summer, winter, track, autocross) and it's silly to have 4 TPMS sets and have to reset it each time I mount a different set.
      08-01-2011, 01:02 AM   #4
pnosker
ti fan
67
Figured it out. In the KOMBI I had to disable "RDC_ALIVE." Doing that, plus changing the VO removed the light after I unplugged the RDC/TPMS module in the trunk.
      08-01-2011, 09:49 AM   #5
justa3series
9
Drives: 2010 328xi
You needed to change VO, set RDC_ALIVE and unplug module? Where module in trunk?
      08-02-2011, 12:50 AM   #6
pnosker
ti fan
67
This one: http://www.m3post.com/forums/showthread.php?t=327609
      08-02-2011, 07:48 AM   #7
justa3series
9
Drives: 2010 328xi
That's emulation, no need. Can be done by coding.
      08-02-2011, 12:46 PM   #8
Elliott@DetailAddict
Drives: E90
He's just showing you the DIY that points out where to unplug the OEM module.
      12-30-2011, 04:08 PM   #9
mathematics
mathematics's Avatar
Drives: 08 328i e93 alpine white
the coding guy from the Bronx that does a lot of coding says that the TPMS disable doesn't get rid of the light. id love to get rid of my TPMS light! can it really be done?
iPhone 6 Plus (iTunes library/iTunes radio/Waze, etc) to Airport Express via AirPlay. Toslink out of Airport Express to Helix P-Six DSP. PHD AF 1.C tweeters, PHD FB 4.1 midranges. Jehnert Door Cards and mid-bass'.
      01-01-2012, 01:17 AM   #10
kiwi29
Team iTouge
kiwi29's Avatar
Drives: 09 M-Tech 328i
it can done by some pros and track prep places. The only problem is that I heard that it messes with the stability of your traction system and how much power your wheels will slip out randomly/
Originally Posted by The HACK View Post
I'm going to use a very simple analogy, I hope you'll understand.
Driving is like having sex.
It really is. You can read up all you want about how to please a woman, you can look at all the diagrams in the world, but just like the clitoris, you won't know what the hell an apex is before you actually find it.
      01-01-2012, 02:37 PM   #11
rexsevn
8
Drives: 335i
It can be done, I coded mine several months ago with no adverse effects (only the benefit of having the light completely off) and no effects on traction control.
      01-02-2012, 09:35 PM   #12
jpirelli
Power is nothing without control
jpirelli's Avatar
33
Drives: E90 + E92
+1
      01-09-2012, 07:49 PM   #13
EYE4SPEED
Ex-Diesel Driver
EYE4SPEED's Avatar
Drives: Audi SQ5
Did you have to unplug any fuses or just the coding? Does this affect warranty with dealer if it is not tpms related?
      01-09-2012, 10:27 PM   #14
rexsevn
8
Drives: 335i
I replied to your pm, I forgot to mention respond to your warranty question.
To my knowledge, I don't know if it will void any portion of your warranty, in my opinion, I don't think it will, I can't think of a reason for why it would adversely affect your vehicle.
I can say though is I have taken my car in to the dealership for service a few times and nothing was mentioned about tpms.
      01-26-2012, 09:14 PM   #15
mathematics
can anyone do this in the NY/NJ area?
      01-30-2012, 01:52 PM   #16
pnosker
ti fan
67
If you come down to New Brunswick, NJ I can try to do this for you. I don't see why it wouldn't work.
      03-16-2012, 11:18 AM   #17
Bendercle
Drives: 2007 335xi 6MT
Gonna revive this thread, I'm attempting to disable TPMS in my 2007 E90.
I removed fuses 13 and 28, removed $2VB from my VO, did FA_WRITE to CAS, used Expertmode to reset CAS, BDSC, KOMBI, and NFRM. It was mostly successful. Before, I would get the light constantly, the one flashing on the dash and the big one in the cluster display. Now the light doesn't come on any more while I'm driving, but it still comes on just once right when I start the car then goes away. I did not try setting RDC_ALIVE to nicht_aktiv, or unplug the RDC module. I will try RDC_ALIVE right away, but I would prefer to not have to mess with the module in the trunk, just because from the DIY OP posted it looks like a hassle. Any insight?
      03-16-2012, 01:18 PM   #18
pinky_and_me
pinky_and_me's Avatar
12
Drives: N54 335xi
Is that when pretty much all lights come on even the check engine and traction ones or does the TPMS light stay on longer?
      03-16-2012, 02:09 PM   #19
Bendercle
I'm talking about the big one in the cluster display, that's the one that comes on. I know what you're talking about, it's not the little ones in the upper area.
      03-19-2012, 01:45 PM   #20
scorpnaz7
Drives: 335i
What color is the light?
      03-19-2012, 08:00 PM   #21
Bendercle
It's yellow.
On a whim I decided to also recode the ABG module, because I figured it also holds a lot of safety/sensor info. I think it worked, because I didn't get the light starting up the car on the drive home from work. Unfortunately I then had to hop on a plane to go on vacation. I will of course know better if the solution stuck when I get back.
One last thing, even after all the steps I did, I still get the little orange exclamation point in my cluster. If I go to Check Control via the BC stalk it will throw up the TPMS light. So the car still "knows" that TPMS is not functioning correctly. Were people able to completely erase all trace of TPMS, or is this the best we can do?
      03-19-2012, 08:06 PM   #22
scorpnaz7
Drives: 335i
Try to also recode the DSC module. I can't remember the exact name, but I think its DSC.
