Driver side read view mirror keeps changing settings, common?
07-30-2011, 03:37 AM | #1 |
Rep 9
I've noticed it a few times, but today it was way obvious. I get in my 335 e92 and the driver side mirror is pretty much Pointing downward. Before I thought it had just been the angle I was sitting in my seat, but this time it was quite obvious it was the mirror, anyone else experience this or know what could be causing it? I don't mess with the memory settings, I use the same key, don't have convenience package. I even had the switch set over to passenger side
07-30-2011, 04:05 AM | #2 |
307
Rep 2,612
Drives: F30 328i Luxury - Sport Auto
Could be your wife. I would plug in the diagnostics and check her for error codes.
Gone: 2006 BMW E60 520d SE 6MT Gone: 2009 BMW E90-LCI 330d SE 6MT Current: 2012 F30 328i Luxury 8AT On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!) |
07-30-2011, 05:14 AM | #4 |
Justin Herass
333
Rep 1,205
I had the same problem. The wires that connect to the mirror are corroded and it not getting a good signal from the ecu. Take it to the dealer, they will replace the motor and connectors.
07-30-2011, 12:56 PM | #5 |
Rep 9
07-30-2011, 12:58 PM | #6 |
Rep 9
When you took it in did they just take your word for it and replace it? Or did they take it apart see the corrosion then replace it? I'm still under 4yr/50k warranty so I'm sure it'll be easier to get replaced
07-30-2011, 12:59 PM | #8 | |
124
Rep 5,627
Tom |
07-30-2011, 02:00 PM | #9 |
9
Rep 369
It's a common problem. I had it too; it would reset itself when I would lock/unlock the doors or hit the memory settings. See if you can duplicate it but the dealer should cover it if you're under warranty.
07-31-2011, 07:29 PM | #10 |
56
Rep 235
I have a problem with my driver's RVM changing whenever I activate the folding mirrors. When I unfold the mirrors the driver's side is always messed up and I have to re-adjust it. PITA.
07-31-2011, 10:03 PM | #11 |
46
Rep 385
I have the same problem with my passenger side mirror. Every morning when I get in my car I always look to see it pointing at the ground or up in the sky. I've even seen it drifting up as I was driving down the freeway. I'm taking it to the dealer... eventually.
2012 F10 535i
2013 E70 X5M 2007 E92 335i - sold |
07-31-2011, 10:14 PM | #12 |
149
Rep 6,604
Drives: e92 335i
take it to the dealer, this is a common problem
08-01-2011, 01:17 AM | #13 |
23
Rep 702
i have the similar problem, i had to readjust the mirror everytime i start the car, not due to memory or key setting, and i didnt realize it when doing my final service b4 warranty ended
