BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > codes saved with time/date
      07-27-2011, 09:29 AM   #1
FrankE90xi
FrankE90xi's Avatar
Drives: Black 2007 BMW 328xi
2007 BMW 328 xi  [8.40]
does your car store the date and time of when a code was poped up because they are going to scan my car to see what day the code came up and if this is possible would disconnecting the battery make the date reset??
18" alzor style 703, 20mm rear spacers, 10mm front spacers, 235/40/18 Nitto Neogen, Afe Stage 2 pro5r CAI, Eurocharged tune, Meistershaft catback exhaust, 35% Window Tints, Taillight and Side Marker Tint, Debadge, Blackout Grille, CF Interior kit, Cyba Scoops
      07-27-2011, 10:48 AM   #2
Neutrino45
Neutrino45's Avatar
62
Drives: XXX
You can use INPA to delete the code but you can't change the time and date.
      07-27-2011, 10:56 AM   #3
FrankE90xi
FrankE90xi's Avatar
will that save the same time and date that it originally happened or it will update it to when u reset it or delete it
      07-27-2011, 12:40 PM   #4
Neutrino45
Neutrino45's Avatar
62
Drives: XXX
you can view the code w/ the original date stamp mileage. i dont remember if it shows a time stamp.
if you delete it, its gone forever. there is no date or time stamp for that action.
      07-28-2011, 09:51 AM   #5
FrankE90xi
FrankE90xi's Avatar
ok and when you restart the car it will pop the code again just with an updated milage and date correct?
      07-28-2011, 11:29 AM   #6
Neutrino45
Neutrino45's Avatar
62
Drives: XXX
Yes, if the problem still exists then it will pop up again w/ the new stamp.
      07-28-2011, 01:26 PM   #7
FrankE90xi
FrankE90xi's Avatar
ok thank u for the info i really appreciate it
