TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Coding issues
      07-27-2011, 01:41 AM   #1
mrtanz
Australia
24
Drives: BMW 2008 325i upgrade
Coding issues
Hi All
I am new to the coding scene
Just received by OBD cable
Running Win7 64bit Ultimate
Issues:
1. Dont have comm port on the laptop
2. NCSEXPERT does not run, gives me message about compatibility, even wen running in compatibility mode
Tried running the program on a Windows XP Virtual PC however comes up with api.dll errors and api32.dll errors.
Any help
Thank You
      07-27-2011, 07:34 AM   #2
mrtanz
Australia
24
installed Win7 32bit in vmware and don't get compatibility message anymore however now in that O/S i get api.dll error
      07-27-2011, 04:29 PM   #3
mrtanz
Australia
24
anyone?
      07-28-2011, 12:17 AM   #4
BMW4Life2112
BMW4Life2112's Avatar
Drives: E90
Try to right click on the NCSEXPERT icon and click "run as administrator"...
      07-28-2011, 08:49 AM   #5
mrtanz
Australia
24
got it all working by copying the dll files
however now when i run inpaload all i get is a white screen
no errors just white screen
      07-29-2011, 07:29 PM   #6
mrtanz
Australia
24
No one can help?
      07-31-2011, 06:57 AM   #7
mrtanz
Australia
24
anybody?
surely someone can help
      07-31-2011, 09:47 AM   #8
fdriller9
Drives: '06 AW 330xi
2006 330xi  [6.44]
Did you install the drivers for the obd cable?
      07-31-2011, 05:26 PM   #9
mrtanz
Australia
24
Yes installed the drivers in the C:\EDIABAS\Hardware\OBD location
Tried newer drivers but kept getting BSOD
      07-31-2011, 05:30 PM   #10
fdriller9
2006 330xi  [6.44]
Hmm I'm not sure if that's where it's suppose to go or not. I just got a regular K CAN OBDII cable for $37 and a R232 to USB adapter and used the drivers that came with the adapter.
The cd that came with the adapter just installed it automatically. I'm assuming in a windows directory. Not the ediabas directory.
      07-31-2011, 07:00 PM   #11
mrtanz
Australia
24
sorry meant i installed the drivers from the ediabas location
      07-31-2011, 10:25 PM   #12
Neutrino45
Neutrino45's Avatar
62
Drives: XXX
Have you tried to remove all of the files and try to start over? Maybe you made a mistake somewhere?
      08-01-2011, 01:08 AM   #13
mrtanz
Australia
24
perfect
Thank You for that it works great now.
However i have an e90, in the PDF it says to click E89.. is that correct or are there newer files i should use. Also when i check the MAN file after saving i dont see the BC_Digital... line
      08-01-2011, 02:44 AM   #14
Neutrino45
Neutrino45's Avatar
62
Drives: XXX
You're welcome. Yes, click E89 for your E90 car.
Here is the Chassis Family Codes List for NCSExpert. (Source: thanks to dadeppa from another forum)
      08-01-2011, 03:33 AM   #15
mrtanz
Australia
24
any ideas about not seeing the BC_Digital in my MAN file?
      08-01-2011, 09:41 AM   #16
Neutrino45
Neutrino45's Avatar
62
Drives: XXX
BC_Digital is in the KOMBI module (there is a mistake in the guide). You need to edit the .TRC file then save that file as .MAN.
      08-01-2011, 07:28 PM   #17
mrtanz
Australia
24
awesome
Just spent that last 1 hr in the car coding different items
Thanks alot for your help
