Major upgrade to base audio system
07-25-2011, 11:17 AM | #1 |
45
Rep 1,032
Drives: 2010 335i Coupe/Space Gray
As most of you know, the base audio system from BMW leaves a lot to be desired, especially for someone who appreciated a good system.
For those interested, here's what I had done: JL Audio CleanSweep® CL441dsp OEM Audio Interface BSW Stage 1 upgrade for front only (upgraded 4" speakers and addition of tweeters) Swapped under-seat 6.5" speakers for factory Hi-Fi 8" Above two powered by a JL Audio XD400/4 amp JL Audio Stealthbox® containing 2 JL Audio 13TW5-3 subs Subs powered by a JL Audio 500/1v2 amp Should be thumping!! The guys at Soundscape Car Audio in McKinney (http://www.soundscapecaraudio.com) did an absolutely amazing installation job! The amp rack was completely custom and much more than I was expecting. They made the cover to resemble the look of the door panel complete with curved wood trim! The sound quality of the BSW upgrade speakers is awesome! A huge improvement over the stock speakers. And the Stealthbox produces really good, clear, hard bass. Here's a couple pics of the Stealthbox and amp rack installed. Enjoy!
COBB Stage 2+ AGGRESSIVE / STETT Cold-Air Intake / STETT Charge Pipe / TiAL Blow-off Valve / ETS 5" Front-Mount Intercooler / Active Autowerke 3" Catless Downpipes / Active Autowerke Signature Exhaust / AST 4100 Coilovers / OS Giken Superlock LSD / All MOTUL Fluids |
07-25-2011, 11:39 AM | #2 |
300
Rep 3,969
Wow, beautiful job! Just to warn you though, BSW speakers have been known to fail with aftermarket amp power, so be careful, and be prepared to change those out in the future!
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
08-17-2011, 11:46 AM | #3 |
Rep 29
Drives: Arctic blue 330i
pictures!!!! looks amazing how much out the door
11-28-2011, 09:56 AM | #5 |
45
Rep 1,032
I don't know what an MS8 is, but the CleenSweep basically takes all the OEM audio signals (Radio, Sat Radio, Nav, Bluetooth, etc.) and outputs a cleaner, flatter signal before it goes into the amps. I still have OEM volume control for everything and didn't have to worry about what kind of outputs the factory system has. Especially useful since everything runs through the iDrive...
11-28-2011, 11:30 AM | #6 |
1911
Rep 13,104
ms-8 does much more than the cleansweep
It provides 8 channels of surround sound and is self calibrating.
The channel output is only 18 watt per channel into 4 ohm or 30 into 2 ohm though. |
12-07-2011, 11:54 PM | #7 |
12
Rep 50
so my radio does not have any audio. Ive tried the fuses and and it doesn't seem to be any burnt fuses. This situation happened to me a while back where one day i came into my car, it stopped working. i went into the dealership and they wanted to charge a ridiculous amount for 1 hour to "reprogram" it. can anyone help me?
01-10-2012, 04:29 PM | #9 | |
7
Rep 40
__________________________
2012 325i Coupe Mineral White |
01-13-2012, 11:33 AM | #10 |
45
Rep 1,032
I had an installer put everything in, but as far as I know they tapped the signal from the speaker wire.
01-23-2012, 03:55 PM | #12 |
45
Rep 1,032
Thanks!! All components and installation charges totaled out to around $3200.
JL Audio CleanSweep® CL441dsp OEM Audio Interface - $300 BSW Stage 1 upgrade for front only (upgraded 4" speakers and addition of tweeters) - $250 Swapped under-seat 6.5" speakers for factory Hi-Fi 8" - Free from good friend Above two powered by a JL Audio XD400/4 amp - $260 on eBay JL Audio Stealthbox® containing 2 JL Audio 13TW5-3 subs - $1040 (10% off during black Friday sale) Subs powered by a JL Audio 500/1v2 amp - $365 (Ugly Box Sale) JL Audio XC-PCS4-2B Amp wiring kit - $75 (Ugly Box Sale) Custom Installation - $800
