TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Confort Access coding ?
      07-23-2011, 09:24 PM   #1
Frenk
33
Drives: e92 328i X-Drive M-Sport
So I have been searching if it's possible to code the confort access option.
Some people says it's not possible because it needs specific hardware parts to work.
Can somebody confirm this ?
      07-24-2011, 08:38 AM   #2
Thunder Dump
That tickles
Thunder Dump's Avatar
11
Drives: '09 328i E93 SGM/CR
Yes there is a lot of hardware involved. It is not just a coded option.
      07-24-2011, 08:57 AM   #3
Tbird1000
Sweden
Drives: BMW 320XD
In the "06a_E90 General Vehicle Electrical.pdf" page 35 the modules involved are shown, as "Thunder Dump" says it's very complex.
      07-24-2011, 10:44 AM   #4
Dracon
Drives: 2013 F10 M5
2013 BMW M5  [0.00]
You would also have to order all new keys and possibly a new CAS unit.
All in all, it's not worth the money to retrofit Comfort Access.
      07-24-2011, 11:18 AM   #5
Frenk
33
Alright tnx
One more thing, I have heard you can start the car with no key (no confort access) if you have previously started the car like one minute before.
So it might not be a good idea, but theoretically could it be possible to code it to make it beliveve the car was just started couple seconds ago, making possible to start w/out key.
Not good for safety i know !
      07-26-2011, 07:20 AM   #6
hiter202
Drives: BMW
Originally Posted by Frenk View Post
Alright tnx
What he said ! Interested in this as well.
      08-09-2011, 12:40 PM   #7
pgh330xi
Drives: 2006 330xi
I have comfort access and the key fob needs to be within the passenger area of the car for it to start. As for adding it aftermarket...the door handles are different as well. There are sensors in them to lock and unlock the doors. Look for little ridges on the top of door handles. if you see them...the car has comfort access.
      08-18-2011, 08:59 AM   #8
platnumdesi01
52
Drives: 2009 335i Coupe
I just got a 09 335i with comfort. Can you start the car from the key?
      08-18-2011, 09:29 AM   #9
thatsosm
Miracle Whip
thatsosm's Avatar
Drives: 07 e90 AW335i
Alright tnx
Your car has to be started already, and the doors have to be closed. Push the On/Off button, take out the key, push the on/off button again, and there you go.
13.16@108.97 2.195 60'
      03-01-2015, 04:54 PM   #10
rogerdiaz
Drives: 2015 335i
So my comfort access died one day. Its not the key fobs,batteries,fuses,actuators. Bmwhat found the options under coding and they are listed as Active.
I even re-coded the options (start/stop without key and handle touc lock) with Bmwhat app.
They just dont work. No dice. Can i swap out module for a new one? Anyone know if this thought process will work?
      07-22-2017, 08:46 AM   #11
Pierre26
20
Drives: 2009-335D Pack M
Sorry to say that you only need INPA to know where is the blem: nothing means that it is PGo module, if not each part that is not running is highlighted (door-handle, antennas, ...) At least verify your Fuse in the JBBE ..
You can swap the PGo module using the same Ref without coding, only need to restart the car waiting for an update of each part.
