Steering Wheel vibration bt. 45-65 mph
07-19-2011, 09:07 AM | #1 |
321
Rep 412
Hi All,
I'm in a very bizarre situation with my 2006 330i with Sports pkg (44k miles). 3 weeks back I got a set of brand new Pirellis from Tire Rack and got them installed at a local NTB. Shortly thereafter I noticed steering wheel vibrations at 45-65 mpg. No vibrations is felt at lower speeds or at higher speeds but only in the range stated above. So I took my car to Firestone to get them Road Force balanced. Once the road force balance was done, I still continued to notice vibrations at the same exact speed and nothing changed. Next, I took my car to a wheel straightening place, (pretty shady establishment I must say) and the guy apparently straightened one of the front wheels and one of the back ones using the straightening machine. Still nothing has changed so far and I've completely run out of options. Took the car to my BMW independent guy and he said that he can see noticeable wheel bends on both front wheels of my car. The weird thing however is that I never had a single steering wheel vibration on my old set of tires. Also, I don't remember hitting any potholes about the same time I got new tires. There's no strange sounds or clicks coming from the car other then the steering wheel vibration while driving between 45-65 mph. I'm considering buying new wheels but before I make that commitment, I want to make sure that I have the issue isolated. Can you guys please help?? Any and all feedback would be greatly appreciated ... |
07-19-2011, 10:32 AM | #2 |
121
Rep 1,568
Sometimes wheel/tire combinations won't balance together. Tire/wheel assembly is probably hitting some sort of frequency range that induces vibration. The tires still may have some sort of characteristic that will induce vibration at certain speeds. It's a crapshoot.
Bottom line, there's no guarantee that even if you're able to balance on the machine, it won't transmit forces when driving. If you have any bends in your wheels (can be seen while balancing as wobbling), there's an ever greater chance of vibrations occuring on a "balanced" assembly. Another option is that something in your drivetrain is causing these vibrations. Best bet to test if it's a drivetrain or tire/wheel is to try another set of tires/wheels from a vehicle that has no problems. If it goes away, you either get the wheels fixed at a reputable shop, or replace the wheels. If there's still an issue with good wheels, the tires have the issue. |
07-19-2011, 01:41 PM | #3 |
BimmerPost Supporting Vendor
2040
Rep 25,989
Sometimes swapping tires will cause a noticeable difference in steering wheel vibrations that you never noticed before. This generally happens because of the tire compound and tread design.
-Charles@VMRWheels
VMR|Wheels | 714.442.7916 |
07-19-2011, 08:16 PM | #4 |
Rep 24
i have the same problem. also had my wheels road force balanced and the guy said that my tires and wheels don't match. so i guess i'll just have to deal with it until i wear my tires out then swap them to new ones. i'm just a little concerned that it might ruin other components of the car like the suspension etc.
07-20-2011, 01:26 PM | #5 | |
2040
Rep 25,989
-Charles@VMRWheels
07-20-2011, 08:04 PM | #6 |
Rep 24
he was showing me that the wheel is balanced but i think it was the "road force" on the tires are exceeding the limits on the machine. i really could not understand what the repair guy was saying that the values on the wheels are ok but the tires are not. he said that changing my tires could solve the problem.
