Knock-Knee'd BMW's
04-12-2007, 04:25 PM | #1 |
8
Rep 196
Knock-Knee'd BMW's
After I purchased my e92 i've been noticing alot of BMW's on the road which is normal I guess. I've been looking at the rear wheels of other BMW's in stop and go traffic and some of them look really "knock-knee'd" like the suspension is bad or they loaded too much stuff in the rear of the car. I pull up beside them and most of the time nothing is in the rear seat (can't tell in the trunk). Just wondering why they look so.... "retarted". I had a friend with a 2000 528i and his looked knock-knee'd from the rear as well without anything in the car.
Is our suspension setup supposed to look like that after many miles of driving or is that a defect?
Le Mans Blue
15% All-around Tint 335i Coupe - Fully Loaded with M-Sport package Light Grey Interior, Grey poplar, black headliner 194 19"Black powder coated polished. |
04-12-2007, 04:31 PM | #2 |
1312
Rep 10,185
Are you reffering to the Camber of the suspension ?
Its what gives the car such great handeling
BMW if you are reading, I need a job, Please. |
04-12-2007, 04:33 PM | #3 |
8
Rep 196
Yes i'm referring to the Negative Camber in the pic above. It just looks like something broke inside the suspension.
So it is normal?
Le Mans Blue
04-12-2007, 04:34 PM | #4 |
Thats all you need to know.
43
Rep 1,188
I think it looks good, My X5 has a lot of negative camber, 335 not so much.
- M2 2018 LBB / Black
- X5 F15 2016 Mineral White / Black 1981 Delorean number 6489 |
04-12-2007, 04:35 PM | #5 |
8
Rep 196
Oh and i've also noticed that the rear tires on my car toe in noticeably when looking from behind (pidgeon toed). Not too much just enough for me to notice it.
Le Mans Blue
04-12-2007, 04:37 PM | #7 |
8
Rep 196
What makes it have alot of negative camber?
I only see some BMW's with negative camber, the rest are vertically aligned.
Le Mans Blue
04-12-2007, 04:40 PM | #8 | |
1312
Rep 10,185
the sport has even more cammber than the regular suspension And the M sport suspension even more It creates great handeling in corners, but eats up the inside lip of the tire faster
04-12-2007, 04:40 PM | #9 |
Rep 40
There are all kind of trade offs for camber and toe and what not which is an entire article in and of itself. If you want to boil it down to a general rule of thumb a little negative camber tends to give better handling/traction while taking corners.
Of course there it's all a delicate balance and there is such a thing as too much. |
04-12-2007, 04:41 PM | #10 | |
1312
Rep 10,185
Looks at some sport cars, they will have the same
04-12-2007, 04:45 PM | #11 |
8
Rep 196
So are the suspension on different BMW's why I see more negative camber on some models or trim levels more than others? Because some bimmers I see just looks like the axle is broken.
Le Mans Blue
04-12-2007, 04:48 PM | #12 |
143
Rep 6,333
Yea when I first noticed the inclined wheels (negative camber), I was really shocked and thought it's a sign of aging suspension on my X5. But then I asked the same question on E90Post after I took delivery of my 330i and noticed the same thing and i realized its a way BMW set up its rear wheels to improve handling!
2017 BMW M4 DCT Lease Transfer: https://f80.bimmerpost.com/forums/sh...8#post23736398
04-12-2007, 04:49 PM | #13 | |
3575
Rep 10,355
Like all those guys said. Negative Camber. Enables our fat@ss cars to handle fairly well. |
04-12-2007, 04:51 PM | #14 |
8
Rep 196
Well that explains it, I just don't see that effect on any of the BMW's at the dealership, I suppose it increases with mileage.....
Le Mans Blue
04-12-2007, 04:56 PM | #15 |
Rep 150
You also see it on cars like G35s, especially when they have passengers in the back.
2007 335i sedan
Black Sapphire/Terra/Cold Weather/Premium/Sport/Step/CA/PDC/Sirius Delivered June 8, 2007 PCD |
04-12-2007, 05:02 PM | #16 |
Now With 33% MORE Sarcasm Free!
157
Rep 3,462
Can't just say it's normal, really. Visually Obvious negative camber prolly means ghetto lowered and NOT re-aligned.
Unless you're at an Autocross event, or a track day, any visually obvious Neg camber is probably the result of torch on the springs and has nothing to do with handling or performance and everything to do with worn out destroyed tires in 5k Miles. On the streets it'll do nothing but look stupid and wear out tires. I'd say that the 1-2deg of negative camber isn't something you are likely to notice, even when looking pretty hard.
A BMW is Just a Car, it doesn't make you smart, handsome, clever, better, cool, or wealthy. |
04-12-2007, 05:04 PM | #17 |
1312
Rep 10,185
Shouldnt
04-12-2007, 05:06 PM | #18 | |
1312
Rep 10,185
04-12-2007, 05:11 PM | #19 |
8
Rep 196
I notice it mostly on X5's and the previous generation 5-series
Le Mans Blue
04-12-2007, 05:19 PM | #20 | |
157
Rep 3,462
Huh, seems that the resultant tire wear would be a little too much... I'll start looking more closely though. Mostly I'm talking about the really Over the Top neg Camber you see on some of the Ricers cars running around here.
04-12-2007, 05:24 PM | #21 |
1312
Rep 10,185
Its not over the top, but you do notice it
04-12-2007, 05:36 PM | #22 |
432
Rep 2,527
