2010 2011 BMW 5 Series Forum F10 how to program interior mirror |
07-14-2011, 11:18 AM | #1 |
39
Rep 136
hi , Guys,
can't program interior mirror , please help
///M5 MCB (2012) TOTAL LOSS
550i M sport (2011) SOLD 545i M sport (2004) SOLD 330i M sport (2001) SOLD |
07-14-2011, 11:43 AM | #3 |
39
Rep 136
07-14-2011, 01:57 PM | #5 |
15
Rep 121
07-15-2011, 11:18 AM | #6 | |
39
Rep 136
but i have wait for 2 mins but it does not flash at all.
07-15-2011, 12:06 PM | #7 |
Occasionally frequent poster
3003
Rep 2,745
It may not work for all garage door openers.
When you press both outer buttons, that clears the memory. Does that work? If yes, then try to program the first button instead of the third button.
Current inventory:
F22 & G05 Cadillac CT5-V Blackwing w/3 pedals Past: E24,E28(3),E34,E36,E37,E38(2),E39(4),E46,E89,E92 (obviously),F01,F06,F10,F30,F87,G12,G30(2),G82(2) |
07-15-2011, 12:12 PM | #8 |
26
Rep 228
Here's how you do it in Canada (we have rolling code door openers), maybe it's the same where you are.
1. Erase all previous codes by holding button 1 and 3 until the light flashes. 2. Hold the button you want to program. At the same time, hold the remote button for 2 seconds, then release and repeat a few times (the remote, not the mirror) while constantly holding the mirror button, the light should change from slow flashing to rapid flashing in about 5-10 seconds. The mirror and the remote are now duplicates, but the mirror is not linked to the opener yet. 3. On the garage door opener unit, there is a program or teach button (usually an orange square button), press it, a light near the button will come on. 4. Press and release the mirror button you just programmed repeatedly until the garage door responds. Good luck, the old style non-rolling code openers were much easier. Last edited by AVIMAX; 07-18-2011 at 08:06 AM.. |
07-15-2011, 12:46 PM | #9 | |
39
Rep 136
07-15-2011, 03:40 PM | #10 |
Rep 100
I had problems with mine too. Eventually got button 2 working. No luck with button 1.
2017 540ix Dark Graphite Metallic/Ivory/Black Dakota
Previous 2014 535ix Imperial Blue/Oyster, Comfort Seats 2011 528i Cashmere Silver/Black Dakota 2001 530i Sport (deceased) |
07-15-2011, 03:59 PM | #11 |
Rep 3
I did the same procedure that AVIMAX describes. However, I still could not program the homelink on the car. The problem was that the battery for the remote was too weak. Apparently more power is needed from the remote to program the car homelink than to open the garage door. After replacing the battery in the remote it worked the first time.
07-16-2011, 12:55 AM | #12 | |
Rep 18
Step3 - The orange/red button on the actual door motor housing allows the homelink mirror to synchronize with it's rolling code. Quote:
07-20-2011, 12:51 PM | #13 |
39
Rep 136
still now did not got a chance to program my interior mirror.
please anyone can help me with it?
07-22-2011, 03:16 PM | #14 |
Rep 25
What is the brand/model of your garage opener? If you have the manual of your garage opener, you will find a page inside it that has the instructions on how to program your car's mirror buttons. If you don't have a hard copy, you may be able to find the manual in Google search.
07-22-2011, 04:19 PM | #15 |
18
Rep 315
ok here is how i did it.. i had 2 controllers programmed on it..
1. hold the controller button and ur car no.1 at the same time.. 2. wait for the lights to blink and its done. *Be sure ur remote controll code matches the numbers allows by ur car.. Ex. Mine is a 10 code remote so it goes perfectly into the car system. hope it helps. |
07-22-2011, 04:37 PM | #16 | |
39
Rep 136
infact i change the remote and paired luckly
07-23-2011, 12:35 AM | #17 |
18
Rep 315
07-24-2011, 02:47 AM | #18 |
99
Rep 162
Reminds me of my sister in law who drove my fully optioned e39 for the first time. I explained to her how to set everything, which buttons to use to change the position of the seats and the mirrors and so on. She happily took off just to stop after a few seconds to ask: Which button do I need to press to adjust the inside rear view mirror?
HAZET Stahlwille Knipex German tools shipped worldwide.
http://www.jensputzier.com |
