How much 87 octane is left in that hose before you begin fuelling?
04-09-2007, 08:29 PM | #1 |
11
Rep 613
Ok, so here's a question. You pull up to the pump at a gas station, the guy before you just filled up his car with 87 octane. You put your credit card thru and select 93. How much of that 87 octane fuel is still in the hose before the 93 starts pumping thru?
04-09-2007, 08:30 PM | #2 |
Too many Alex's, from now on, call me Beaufort
342
Rep 6,188
None if you have independant hoses for each octane.
13 HD FatBob
17 A4 Glacier/Black 1st Edition/Pre+/Sport/EurocodeTMD/Racechip 16 S6 (gone),14 S6 (gone),14 S6 (gone),13 S6 (gone),10 S4 (gone) 07 335i(gone) |
04-09-2007, 08:33 PM | #4 |
Rep 92
Approximately one hoses worth.
No idea, but I doubt it is enough to worry about, if you are sticking at least a half a tank in I would think it is about 1% of what goes in your car, but I'm just pulling numbers out of my ass. I guess you could just spray the first second of gas on the ground and then stick it in your car. |
04-09-2007, 08:34 PM | #5 |
342
Rep 6,188
I dont think anyone here is a gas station fuel pump engineer, but Id have to guess not enough to affect the rest of the tankful.
13 HD FatBob
04-09-2007, 08:37 PM | #6 | |
4972
Rep 10,200
Drives: 2024 Golf R / 2022 718 Spyder
+1--surely this amount would not matter...
Past rides: 2016 981 BGTS, 2020 MINI JCW, 2017 F80, 2015 981 CS, 2014 F22 235, 2011 E82 135, 2008 E82 135, 2007 E92 328, 2007 E92 328 (My lady drives an OG M2. So does my dad)
04-09-2007, 08:37 PM | #7 |
122
Rep 425
FWIW, I have on occasion filled up with Plus (89 Octane), with no noticable knocking or decreased performance.
2019 G20 330i xDrive Med. Blue/Cognac Leather ZCV|ZPP|ZPX|HK|Remote Start (Ret'd)
2016 F06 640i xDrive Med. Blue/Red Leather MSport|B&O|Driver Asst+|Cold|Night (Ret'd) 2013 F30 335i xDrive Mineral Grey/Black Leather (Ret'd) 2011 E90 328i xDrive Space Grey/Black Leather(Ret'd) 2009 E90 328i xDrive Monaco Blue/(Ret'd) 2007 E90 328i xDrive Graphite (Ret'd) |
04-09-2007, 08:41 PM | #8 |
11
Rep 613
04-09-2007, 08:42 PM | #9 |
11
Rep 613
04-09-2007, 08:50 PM | #10 |
45
Rep 1,738
If this in the least bit concerns you, wait until you see a big $$ vehicle filling up. Chances are that they will be using premium, and just make sure you are next in line. But, it's not worth worrying about.
2006 325i - Sparkling Graphite
2000 S2000 - New Formula Red 2007 Chev Silverado crew cab Z71 |
04-09-2007, 08:52 PM | #11 |
342
Rep 6,188
Or, find a gas station that has independant pumps.
13 HD FatBob
04-09-2007, 08:53 PM | #12 |
99
Rep 990
The car has a knock sensor. Don't worry about it.
BMW : Sine qua non
Mods: Blacklines | Rear Seat Power Outlets | Rear Fog Lights | Ashtray Garage Door Opener |
04-09-2007, 08:54 PM | #13 | |
36
Rep 540
im gonna do that next time i fill up |
04-09-2007, 09:43 PM | #14 | |
Rep 4
Frankly, it depends on the dimensions (diameter and length) of the hose to a large extent. You can do a quick calculation (gasp!) using conversion factors available on the internet. Let’s say that the diameter of the hose is 1 inch. The area is then pi (3.1415) r squared (or ½ diameter squared). So the area of a 1 inch diameter hose is (3.1415*.5*.5 = .785 inches squared). Multiply that by the length of the hose. Let’s assume that an average hose is 10 feet long. That’s 120 inches times .785 square inches. Multiply this and you get about 94 cubic inches. From the internet, you’ll find that 1 cubic inch = 0.0043 gallons, so .0043*94 = 0.4 gallons (just about). Answer….you get about 4/10s of a gallon of 87 octane in the hose. Assuming that you put $5 of 93 octane in your tank (at $3.50/gallon), you’d be putting in 1.4 gallons total, of which .4 gal would be 87 octane and 1 gallon would be 93 octane. If they mix evenly, your octane for that particular $5 fill would be about 91.3…..still above the minimum level recommended for a 335i. If you pay more per gallon, you'd have even less octane for your $5. But, even though I agree that this is not anything to worry about, it IS a surprisingly large volume relative to a small “fiver” fillup, and definitely more than 1% for even a full tank. Like I said….couldn’t resist….. |
04-09-2007, 09:50 PM | #15 |
STEVIL Empire
218
Rep 6,297
I wouldn't worry about the amount of 87 octane left in the hose as much as the overall quality of the gas that the station supplies to it's customers.
2007 E92 328i 6MT-Space Gray/Black Dakota/Gray Poplar w/heated seats-PCD 4/27/07 (SOLD)
2009 E90 328i xDrive 6AT-Space Gray/Oyster Dakota/Dark Burl Walnut w/ZPP,ZCW,Xenons-ED 4/17/09 - Redelivery 5/30/09 (SOLD) 2014 E84 xDrive28i 8AT-Alpine White/Black Nevada/Silver Matte w/ZMV,ZLP,494 - DD 3/14/14 (SOLD) |
04-09-2007, 10:24 PM | #16 |
137
Rep 1,914
The key word would be noticeable. In reality there is a reduction in performance. Your car's sensors will adjust the timing to allow you to run on lower octane with no damage to the engine. You actually will get better mileage. Car and Driver did a test on this a few years ago and found that the more performance oriented you engine is, the greater the loss in performance with using regular VS premium, BUT in all cases, the drop in performance was not that great. That is probably why you don't notice it. BTW, one problem with running regular gas is that MANY brands of gas do not put the same amount of detergents in the regular gas as in the premium. But some do.
04-09-2007, 10:29 PM | #17 | |
98
Rep 3,618
2016 Mercedes-AMG CLA45
2013 Mercedes-Benz B250 - Gone 2010 Mercedes-Benz C350 4Matic - Gone 2006 BMW 330xi - Gone 2001 Infiniti QX4 - Gone |
04-09-2007, 10:35 PM | #18 |
Your resident 4um troll
125
Rep 2,020
no probably more about 2 hoses worth, the hose goes to the top, you dont think the tanks are in the roof do you?
im pretty sure the selector is about 1/4 of the way up the unit.. so.. a lot i would be willing to bet at least a gallon makes me want to use the three hose type pumps on an off note, i had a dream (or nightmare rather) the other day that i filled up with diesel!!! oh the horror, i was running around the station wigging out trying to figure out what to do, i ended up sucking it out of the tank with a piece of bamboo??!!! let freud have fun with that
RAWRrrrr
04-09-2007, 10:38 PM | #19 |
125
Rep 2,020
zoomy, those hoses have an interior diameter of more than 1 inch, i would say AT LEAST two inches, which would do much more than double your calculations
RAWRrrrr
04-09-2007, 10:49 PM | #20 | |
Rep 14
But I got a headache just reading it. Nice post. |
04-09-2007, 10:59 PM | #21 | |
Rep 4
to gregL and McDeb...I got a headache writing it. Whooo! Just wanted to have a little "fun" with the response - did think it was an interesting question though, and I'm surprised with the answer, even if on the low side. |
04-09-2007, 11:33 PM | #22 |
125
Rep 2,020
yea i dont even care that some asshole is getting a gallon ro two of MY 93 octane, he can have it, i just dont like that im getting his shitty ass 87 octane
im going to start hanging out at gas stations and waiting for other HP cars to fill up and pulling in behind them lol
RAWRrrrr
