BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Alarm beep on lock/unlock
      07-07-2011, 10:54 AM   #1
uweric5985
uweric5985's Avatar
32
Drives: BMW E90 LCI 323i
2009 BMW 323i  [9.50]
I can successfully code the Alarm beep on lock/unlock on my 2009 E90 LCI, but this doesn't work on my friend who has the same car as me.
Are these the right codes? The excel says 2009 model is not supported but I can get it works on mine...
Alarm beep on unlock DWAI QUIT_AKUST_ENTSCH
Alarm beep on lock DWAI QUIT_AKUST_SCHAERF
Performance: K&N High Flow Air Filter | AA Tune Stage 2 | SuperSprint Quad Exhaust
Handling: KW V2 | AP Racing 5200 4 Pots Front Calipers with 330mm J-Hook Drilled Disc | Matt Black 19" Advan RZ-DF
Cosmetic: Gloss Black Roof | Gloss Black Front Grilles | M3 Style Trunk Spoiler | Performance Front | M-Tech Rear Bumper | M-Tech Steering Wheel
      07-07-2011, 10:58 AM   #2
uweric5985
uweric5985's Avatar
32
When I change both to "aktiv", lock beep is on but unlock beep is off...
      07-07-2011, 12:43 PM   #3
Neutrino45
Neutrino45's Avatar
62
Drives: XXX
Did you reset the modules by processing the car or processing individual modules w/ a blank .MAN file when you first installed your and your friend's alarm?
      07-07-2011, 12:46 PM   #4
Elliott@DetailAddict
Drives: E90
Just go into the idrive or bc stalk and uncheck then recheck the chirp confirmations. should be fine.
      07-07-2011, 11:06 PM   #5
uweric5985
uweric5985's Avatar
32
No, I didn't. I just use the .man file that I use to my car.
Can I do the reset now?
I had coded the fold mirror and digital speedometer on his car. Hopefully I didn't mess it up..
      11-03-2011, 02:21 PM   #6
AcidLotus
35
Drives: 2020 X3 M40i, 2014 640i
I was thinking about this this morning, but perhaps from a different angle. My car with alarm beeps when I lock it that one time. But as I'm walking away and my slight OCD kicks in, sometimes I'll grab the fob and hit the lock button again (just to make sure I actually locked it and wasn't thinking about some other time)... I don't hear or see anything, unless I'm standing right up next to the car, in which case I can hear the door lock actuators cycling. Is there a way for the alarm to beep every time I press the lock button, or for the lights to flash a certain way or something?
      11-04-2011, 12:13 AM   #7
genix
Drives: e92 30i (2009)
Interesting. I also like that option.
Gx
      11-04-2011, 02:34 AM   #8
1QuikWS6
No 55mph
1QuikWS6's Avatar
1616
Drives: F32 435ix MSport
My retrofitted alarm on E92 beeps upon lock & unlock, lights also flash on lock, & welcome lights come on upon unlock.
I added the alarm to my VO though (which is really the correct way to do it) all the alarm functions, panic, etc. were automatically enabled after VO update.
Yes, you can go into iDrive or use your stalk to control if & when the beeps sound and/or light flash - but all these features were already ON once I updated my VO.
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
      11-04-2011, 11:58 AM   #9
Drives: E90
The selection fields are added but on a couple of cars I've coded there is a slight glitch where they don't beep on lock. So I have to uncheck the confirmation field and recheck it. No biggie.
Originally Posted by Cynical View Post
If ur close enough to hear ur car the. U should be close enough to see it.
Courtesy interior lights illuminate with second push.
And if I remember correctly from my e39... A second push of lock button within 30 seconds of first disables interior motion sensors.
So your double tab is prob not a good thing.
Program the mirrors to fold. Then you'll see them up and know ur car is locked.
Yes a double push will illuminate the clown nose solid for a brief period indicating the sensors have been disabled.
I also do the folded mirror trick lol
      03-06-2012, 09:37 PM   #10
droptop335
Drives: '07 335i (E93)
Hey folks, I did a quick search and didn't find the exact answer I need:
I have a 2007 E93, no alarm system. It is completely stock, and does not beep at all when I lock or unlock it. The dealer just gave me a 2012 loaner car and it does beep on lock/unlock. I had this on my old 1997 528i, and really miss it. Can a 2007 be coded to beep on lock/unlock, even though it does not have an alarm? Is an alarm required to get the beep or does the car have beep capability that can be accessed through coding?
Thanks in advance for your help!
Alpine White/Coral Red/Gray Poplar Convertible Sport/Prem/Step/Comfort/Nav/Sirius
MHD Stage 1 Flash, M-Factory Helical LSD
By the way people: USE YOUR F&*#ING TURN SIGNALS! Pass the word.
      03-06-2012, 09:44 PM   #11
O HELLA BMW
I <3 My E93
O HELLA BMW's Avatar
Drives: 12” 335is vert
so my 2008 bmw 335i covertible is prewired for the factory alarm, since i have the red clown nose on the rear view mirror. so i ordered the oem factory convertible alarm system from tischer bmw. i went to my local dealership and they said since i installed a LCI IDRIVE Controller(this is the idrive controller found on '11 bmw's) that my alarm cannont be coded to work. meaning no BEEP noise when unlocking or locking....... but when i lock my car my clown nose does blink but i just dont have no BEEP sound at all.....
they said i need to install the old IDRIVE controller in order for my oem alarm to work..is this true? or could a shop other then the bmw dealership code it to beep when locking and unlocking?
Bagged and Wrapped E93 335i
      03-06-2012, 10:13 PM   #12
droptop335
Are you saying that if I have the clown nose, then the car is pre-wired for alarm? I have the clown nose...it currently does nothing.
How much was the alarm system from Tischer?
      03-06-2012, 10:17 PM   #13
O HELLA BMW
I <3 My E93
i believe so, as long as you have the red clown nose i believe your car is prewired then...
its $155 +shipping
http://www.trademotion.com/partlocat...047&startrow=1
      05-23-2012, 04:59 PM   #14
Messiah62
11
Drives: 2011 335D
I have a 2011 335d with the clown nose. I think I have an alarm but i dont have a beep. I also do not have navigation. How do I enable the beep?
      05-23-2012, 06:54 PM   #15
Drives: E90
No after Mid 2009 you are not prewired regardless or red clown nose.
Hold your trunk button on your keys for 3-4 seconds, if it doesn't trigger the alarm you don't have it.
      05-23-2012, 09:43 PM   #16
Messiah62
11
Drives: 2011 335D
Damn so that means I'll never have a beep when I lock my car. I have a loaner today and I wish I had it.
      05-24-2012, 01:11 PM   #17
Drives: E90
Unless you install an aftermarket solution or can source a Euro Retrofit kit that is rumored to exist for non-prewired cars (US dealers won't know about it or be able to order).
      07-07-2012, 08:55 PM   #18
dataspike
dataspike's Avatar
Drives: It's got 4 wheels
Question
Hey guys... I had my alarm coded by one of the SoCal vendors and noticed I have no control over the alarm in iDrive or on the Stalk... did the vendor not do something, or did I not ask for something specific?
      07-12-2012, 12:48 AM   #19
Jhayd11
Drives: 2009 335D
Without mine being prewired, does anyone have suggestions on getting my 335d to beep.
iDrive control would be nice, but as long as I don't need a second FOB ad can just hear a beep when I hit lock and unlock, I don't even need a real alarm.
      07-12-2012, 12:53 AM   #20
myfly335
myfly335's Avatar
Drives: 2011 e90 sport pkg ALL BLACK
2011 BMW 335  [0.00]
dont u need that module in you car to do this? i have a lci 2011 e90 will this code work on mine?
      07-12-2012, 12:59 AM   #21
Drives: E90
I would go get your money back for an incomplete job. Make sure you are looking in the right place: Confirmation under Door Locks.
Who did your coding?
Best bet would be an aftermarket alarm with canbus interface. But iDrive control won't be possible.
Yes you have to have the alarm hardware installed.
      07-12-2012, 01:03 AM   #22
Jhayd11
Drives: 2009 335D
Thanks Grant!
Search this Thread:
Advanced Search
