BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Wheels + Tires Sponsored by The Tire Rack
  TireRack
KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK!
      04-08-2007, 10:39 AM   #1
E36325is
Hong Kong
18
Drives: 1M coupe
official tyre size?
Does any body know the offical F/F tyre dimensions for the E92 M3? Interested to know for 18/19.
360mm front brake disc is impressive but single piston caliper again? :mad:
      04-08-2007, 10:55 AM   #2
Martinmaxx
Martinmaxx's Avatar
Argentina
Drives: E39/E46/E87/E92
I´ve read that they are 245/40 & 265/40 on 18". As you can see, the wider rears have the same aspect ratio as the fronts (40), making those taller overall. This situation is very common on Ferraris, Lamborghinis, etc, but new to BMW (which always had lower aspect ratios for the wider rears).
I do not know the tire sizes for 19". The Geneva concept had Michelin Pilot Cup tires from the E46 CSL in 235/35 & 265/30, but I guess that the production version of the E92 will have even wider tires (maybe 245/35 & 265/35).
'10 E90 325i LCI Space Grey l Step w/paddles l iDrive Pro Navi
'07 E92 335i Space Grey l Grey Poplar l Saddle Brown l Anthrazit Headliner l Active Steering l BT l Step l LC LM l Eibach l Aero Front Lip l M3 Rear Spoiler l Performance Steering Wheel w/Paddles
'97 E39 540i Aspensilver l 6 MT l EDC dampers + Eibach l Xenon l Comfort seats l TV
      04-08-2007, 11:04 AM   #3
remmib
remmib's Avatar
Norway
1566
Drives: 2013 F10 520d M-Sport
Yes, tire size for the 19" 220 M are 245/35 and 265/35
      04-08-2007, 05:54 PM   #4
swamp2
swamp2's Avatar
Drives: E92 M3
Perhaps
Only if the 19s for production are identical to the 19s shown on the concept car. I would say it is likely but not yet a sure thing.
      04-08-2007, 06:27 PM   #5
GregW / Oregon
Commander-In-Chief
2070
Tire sizes
Per the German price list, the stock wheels are 8.5/9.5 x 18 w/ 245/40 & 265/40 ZR tires. The optional 19s are same width but with 35-series tires, of course.
Greg Lake Oswego, Oregon, USA
2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450
      04-08-2007, 06:33 PM   #6
Youngen
Bulgaria
15
Drives: 118d
On the (red) one, on which the official photos and videos were made, there are 245/40 18 on both front and back. But I'm sure it won't be like this on the production vehicles.
      04-08-2007, 06:45 PM   #7
GregW / Oregon
Commander-In-Chief
2070
No, the rears on that car are definitely larger than the fronts. No way they they would showcase a square setup on the M3.
      04-08-2007, 06:50 PM   #8
Youngen
Bulgaria
15
Drives: 118d
^ I thought the same man, but look at the pictures. See for yourself.
      04-08-2007, 10:41 PM   #9
E36325is
Hong Kong
18
Drives: 1M coupe
Check out the 19 inch rims on the German website... only the old 19inch rims...
      04-08-2007, 11:53 PM   #10
swamp2
swamp2's Avatar
Drives: E92 M3
Brakes
Check out the brake discussion here, specifically on the number of pistons. 99.9% likely it will be twin piston front, single rears, (despite the error in the pdf spec sheet).
      04-09-2007, 01:03 PM   #11
2m3
11
Drives: 1995 M3, 1988 M3
I´ve read that they are 245/40 & 265/40 on 18". As you can see, the wider rears have the same aspect ratio as the fronts (40), making those taller overall. .....tires (maybe 245/35 & 265/35).
If this is true that it will have front 245/40 and rear 265/40 , the rear has larger diamater than front. It is interesting to see how DSC, DTC, etc works on tires with different rolling per minute.
It is better if they have 245/40 front and 265/35 rear or 275/35 rear.
      04-09-2007, 01:15 PM   #12
Martinmaxx
Martinmaxx's Avatar
Argentina
The reason for using taller tires in the rear is to be able to get a bigger tire contact patch, without the need to use even wider tires. It is not a bad thing to have! The Ferrari F430 has 225/35 fronts and 285/35 rears. Same aspect ratio for both axles, but with 60mm wider rears.
Regarding DTC, ABS, etc, they all work based on a signal from the wheel rotation sensors, which is then processed by the corresponding electronic module. By applying a correction algorithm, the information from the rear wheels can be easily adjusted by the BMW engineers.
      04-09-2007, 02:21 PM   #13
2m3
11
Thank you for your response. What do you mean by "using taller tires on the rear is to be able to get a bigger tire contact patch"? DO you mean the side wall will flex and compress?
I think 275/35 or more still fit under rear fender.
THis is the first M to have rear tire with taller diameter than the front.
      04-09-2007, 02:38 PM   #14
Martinmaxx
Martinmaxx's Avatar
Argentina
Since the overal diameter is bigger, the contact patch is also bigger (longitudinaly). The curvature of the taller wheel is flatter, and therefore, puts more rubber on the ground at once. That is why dragsters have not only wider but also taller wheels on the traction axle... (to maximize traction).
I believe this is the first BMW (not only M) to have taller rear wheels.
Porsche is also starting to use taller rear wheels now. Until the 996, they had almost identical diameters for front and rear wheels, but since the 997, they are using taller rears. For example the 997 has 235/40 18 up front and 265/40 18 on the rear, while the 993 had 225/40 18 and 265/35 18.
      04-09-2007, 05:55 PM   #15
2m3
11
Thank you again Martinmaxx. This is something new to me, but glad that you opne up my eyes on this tires set up.
I notice NSX, G35, 350Z, IS350 all have taller diameter rear tire besides Ferrari, Lambo, etc.
      04-09-2007, 05:59 PM   #16
2m3
11
Since the overal diameter is bigger, the contact patch is also bigger (longitudinaly). The curvature of the taller wheel is flatter, and therefore, puts more rubber on the ground at once. That is why dragsters have not only wider but also taller wheels on the traction axle... (to maximize traction)......and 265/35 18.
HI Martinmaxx,
Is there any benefit of having smaller diamater tire at front axle?
      04-09-2007, 07:32 PM   #17
Martinmaxx
Martinmaxx's Avatar
Argentina
HI Martinmaxx,
Better steering feedback due to lower unsprung weight.
      04-09-2007, 09:04 PM   #18
MisterBMW
7
Drives: BMW
18" or 19" which is better?
The videos of the red ///M3 going around country roads appears to have 18" wheels, not 19". While I feel 19" will give the M a better and more aggressive look, will it affect ride comfort even with the 40-aspect ratio tyre at the rear?
      04-09-2007, 09:25 PM   #19
GregW / Oregon
Commander-In-Chief
2070
Ride comfort with 19s
Certainly it would have a minor effect. However, I went from 18s to 19s on my E46 and barely noticed the difference. The 40-series tires will have about the same sidewall as 45s on the E46. Should be fine.
      04-10-2007, 09:47 AM   #20
2m3
11
Thanks again
      04-10-2007, 10:02 AM   #21
E36325is
Hong Kong
18
Drives: 1M coupe
I think 265 with 35 aspecct ratio (19inch) should affect the ride quality that much. My Box is using 265 40 18inch in the back and that's pretty cushy.
      04-10-2007, 10:39 AM   #22
M3_2010
M3_2010's Avatar
Drives: M3 CiC
Don't try this if you have an M3 in NYC..... The roads are rough...
Search this Thread:
Advanced Search
m3post
