The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Datatransmission to Interface Disturbed
      07-02-2011, 08:11 AM   #1
jwozz
Drives: 2013 F30
I read with great intrigue the coding pages and thought I'd give it a go - and have become stuck so interested in your collective advice.
Basically I keep getting the 'IFH-0003 DATATRANSMISSION TO INTERFACE DISTURBED ERROR' when I try connect with this cable on a Win XP SP3 machine to my 2008 E90.
Here is what I have tried:
1. Installed the default driver (with correct settings), INPA 5.0.1 , EDIBIAS 6.4.3 and NCSEXPERT 3.0.8 that came with the cable. - No luck
2. Updated the driver to latest available on FDI website - No luck
3. Updated the daten files to V40 - No luck
4. Updated EDIBAS to 7.2.0 - No luck
5. Checked pins 7 & 8 - No luck
6. Tried updating the FDI chip as per instructions - No luck
7. Repeated all the above steps with xxxjecxxx's NCSExpert package - No luck
For good measure also tested on a Windows 7 laptop, and a 2007 E90.
I'm at a loss to find any solution and think it may be a faulty cable. Interested in thoughts?
      07-13-2011, 08:07 AM   #2
fdriller9
Drives: '06 AW 330xi
2006 330xi  [6.44]
Idk if you firgured this out yet or not but if you keep the hazards on, it will prevent modules from going to sleep/disturbing data transmission.
      07-14-2011, 06:55 AM   #3
jwozz
Drives: 2013 F30
Haven't had any luck as yet. I tried on a different car and have concluded that the cable may be faulty.
Shall let you know how I go.
      07-14-2011, 07:28 AM   #4
DESI4life10
DESI4life10's Avatar
201
Drives: Coding: Desi4life10@gmail.com
I had the same problem. Cable worked fine for the first 7 months and then all of a sudden got this error. Did everything that the op outlined and even used another laptop. Basically, I am now waiting for a replacement cable in the mail (on its way).
      07-14-2011, 08:56 AM   #5
giovane
Drives: 2007 e92 335i, 2008 e70 3.0si
Crappy chinese cable. I had to buy a new one.
Did you try checking if your obd.ini has the right settings?
      07-14-2011, 01:39 PM   #6
fdriller9
2006 330xi  [6.44]
Did you guys try the hazard trick?
      07-17-2011, 07:56 AM   #7
jwozz
Drives: 2013 F30
Just impatiently waiting for the replacement cable.
I didn't know about the hazards trick, but shall do that when the cable arrives.
