Headunit help
06-30-2011, 01:55 PM | #1 |
Rep 98
Headunit help
I have just fitted a Kenwoord headunit today, however, it keeps loosing its memory and returning to factory settings after the car has been parked 10 mins or so.
I have tried swapping over the red and yellow wires, and this made it loose memory immediately when ignition was switched off. Which wire is permanent live??? |
06-30-2011, 02:09 PM | #2 |
Dieseasal
204
Rep 6,881
I believe you need to run a wire from ignition or similar. The car is designed to have a head unit that stores settings to the most optical network rather than just be standalone. Therefore when the comfort circuit shuts down after 15mins you will lose all settings.
I believe there's an adapter you can buy that deals with this. Andy at Car audio security sorted it out for me in mine.
Previously: 2003 Peugeot 206 1.6 8v | 2006 E90 320d M-Sport, 19" BBS CH, Full Ice-cold JL audio install, August 2010 Total BMW 6 page feature car. | 2003 Nissan 350Z GT Coupe 286BHP
Now:2010 E92 LCI 335d M-Sport |
06-30-2011, 03:46 PM | #3 |
363
Rep 5,984
You need to run a power lead from the battery to the 12v constant.
There is a place in the footwell somewhere but don't know where, but battery is best. Everything else in the car goes to sleep after 15 minutes so that is your only choice. |
07-04-2011, 08:28 AM | #7 | |
Dieseasal
204
Rep 6,881
07-04-2011, 09:39 AM | #9 |
Dieseasal
204
Rep 6,881
Car audio security supplied it (Well Andy from there).
Single din fascia adapter. The important thing was I wanted it to be central rather than off set. Made it harder to find..
07-04-2011, 10:59 AM | #10 |
58
Rep 2,398
um.. doesn't look very central to me central to the car i am guessing you mean? as it's quite clearly over to the left a bit in the dash
it really does look good, it's a strong contender for not having iDrive imo might impact residuals tho, you know.. being modified cool! |
