Can't get INPA program to work
06-15-2011, 12:42 AM | #2 |
14
Rep 96
Drives: E90
I couldn't get INPA to work either. The fix for your error can be found by editing some values in the registry editor (i.e. Regedit). You will need to for it, you should find your solution because it's a common error. Other than that I just skipped using INPA and only use the program to make sure my computer is communicating with my car. After I have both dot's black, I proceed to open NCSEXPERT and code the car.
06-15-2011, 08:36 AM | #3 | |
56
Rep 1,063
What else could my problem be? |
06-16-2011, 02:17 AM | #4 |
14
Rep 96
Drives: E90
Make sure you plug the cable into the car and your computer before you turn the ignition on. You can try waiting until the red dot on the cable turns off, then start INPA. If both black dots are still not there, then close INPA and reopen it. Sometimes I have had to close and reopen INPA 3 times until the black dots were there. Let me know how that goes...
06-16-2011, 08:37 AM | #5 | |
56
Rep 1,063
