BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > NSCexpert on win 7 64-bit working
      06-13-2011, 08:00 PM   #1
325xi-06
manifold conversion 325/330
325xi-06's Avatar
Faroe Islands
Drives: 325xi 06
so i finally got it to work in win 7...
stuff you need is.
VMware workstation
win xp 32-bit iso file.. file is about 700 mb.
daemon tools lite
winrar.
      06-13-2011, 10:50 PM   #2
azwillnj
318
Drives: 2023 M340i xDrive
Yes, or winXP mode in win7 ultimate...
I can confirm that winXP mode works on 64 bit win7 Ultimate N works.
Alex.
Current: 2023 G20 LCI M340i xDrive
History: 2005 E90 325i > 2008 E90 328xi > 2011 E90 LCI 335i xDrive > 2013 F30 328i xDrive > 2016 F30 LCI 340i xDrive > 2020 G20 M340i xDrive
WE ARE!
      06-14-2011, 02:20 AM   #3
E90aL
Drives: n52
Alex.
how did you set it up? i get a api.dll missing when I run NCS. Im on win7 Ultimate 64 bit.
      07-27-2011, 08:11 AM   #4
mrtanz
Australia
24
Drives: BMW 2008 325i upgrade
hi
did you get an answer to the api.dll??
      07-28-2011, 04:07 PM   #5
fdriller9
Drives: '06 AW 330xi
2006 330xi  [6.44]
You should just google the api.dll file and download it and place it in it's respective directory.
Probably in system 32 folder.
      08-12-2011, 07:04 PM   #6
Ushtari
Drives: BMW E90 320D 177HP
installing d-can cabel on vm ware
I would like to know how did you installe the cabel in vm ware?
      08-23-2011, 12:19 PM   #7
justa3series
9
Drives: 2010 328xi
Install it as normally. Plug cable in and attach it to running VMWare instance. Then it will come up asking for drivers and you install like normal hardware.
      08-24-2011, 01:41 AM   #8
rage
Drives: 2006 325xi E90
Yeah that doesn't work, just tried it myself. I then get an error about not being able to run a 16 bit program.
      08-30-2011, 06:19 PM   #9
rage
stuff you need is.
VMware workstation
daemon tools lite
winrar.
I couldn't get it to work under Windows XP from a virtual machine.
I used VMware workstation (could probably use any major virtual machine software, a good free one is Virtual Box although I haven't tested it in the situation)
Windows 7 Ulitmate 32bit iso (about 4.5 GB), although really any 32 bit version of Windows 7 should work fine.
That's all you really need, no need to burn or artificially mount it as VMware and pretty much any other virtual machine out there can read the iso right from your HD.
VMware won't seem to recognize the cable until you actually plug it in to the ODBII port, at which point you can attach it to the virtual machine. I also installed the cable drivers from here ahead of time: http://www.ftdichip.com/Drivers/VCP.htm This is important if you won't be able to get a wifi connection from your vehicle.
Also make sure in Device Manager, that the Serial Connector is set to COM1. If you have something set on COM1 move it first to an open COM port and then move the Serial Connector to COM1.
Follow the directions as posted in the Coding Success thread.
Enjoy.
