TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Risks of coding
      06-13-2011, 03:43 PM   #1
jazza
jazza's Avatar
301
Drives: F32 428i
Exclamation Risks of coding
Is there any risk of damage a module?
How can I revert to the original?
What if I make any subsequent reprogramming at the dealership, there may be some conflict, apart from losing the coding?
I'm talking about coding with NCS Expert....
      06-14-2011, 08:12 AM   #2
jazza
jazza's Avatar
301
Drives: F32 428i
No answers, no risks
      06-14-2011, 08:16 AM   #3
onebadmofo
onebadmofo's Avatar
346
Drives: 2008 E90 M3
Very hard to mess up and easy to reverse all the changes.
The biggest problem that has ever occurred to me is coding a newer instrument cluster with older files. After coding the cluster stops working and you get "Speedometer Malfunction" error on iDrive. Just recode with newer files and that's it.
      06-14-2011, 08:23 AM   #4
jazza
jazza's Avatar
301
Drives: F32 428i
I am heartened to hear that. I read some threatening comments...
      06-14-2011, 09:24 AM   #5
6cylinder
6cylinder's Avatar
Drives: E92
Hi,
normally you can not damage something with NCS and you can always restore all moduls defaults. Only flashing is dangerous. So feel free in coding with NCS. But be sure that you are using a current issue of ISTA files.
      06-14-2011, 10:26 AM   #6
maximal
23
Drives: E70,E83,E87,E90,E93
Originally Posted by 6cylinder View Post
Hi,
Where to find up-to-date ISTA files?
      06-15-2011, 02:15 AM   #7
6cylinder
6cylinder's Avatar
Drives: E92
ISTA V2.41 is the latest one. Ask google for it.
      06-24-2011, 09:30 AM   #8
justa3series
9
Drives: 2010 328xi
It's tough to brick a module using only NCS. The cool thing about NCS if you try to code non-standard values or wrong values when manipulating the PSW_FSW it will reject it and won't allow coding, although it is posible to mess up operation of the car by coding something incorrectly, say for instance the airbag (ABG) module. There is a updated list via google docs of tested/working items to code.
      06-24-2011, 11:37 AM   #9
woodpecka
woodpecka's Avatar
68
Drives: E91
The bigger risk is to get an empty battery.
