Help! Does a new battery need to be 'registered' to my car?
06-13-2011, 02:27 PM | #1 |
115
Rep 253
Over the weekend my car stalled out. I had to towed to the dealer. They told me, among other things, that it needs a new battery, at $500!
They said it had to be 'registered' to my car so it would not over work the alternator. I'm assuming she meant 'calibrated'. At any rate, does this hold any water? Has any one ever heard of this? What is to stop me from just buying a quality battery and replacing it myself? Thanks! |
06-13-2011, 02:36 PM | #3 |
103
Rep 2,783
If replacing with the same type of battery then it needs to be registered otherwise it needs to be programmed. http://www.e90post.com/forums/showthread.php?t=542737
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
06-13-2011, 02:37 PM | #4 |
Ikea enthusiast
334
Rep 8,140
Drives: '07 E92 335i
Yes. And it can only be done at the dealer or an independent shop that has a GT1 tool. Welcome to modern BMW ownership.
06-13-2011, 02:44 PM | #5 |
103
Rep 2,783
BT Tool can register the battery, not sure about programming though.
06-13-2011, 03:57 PM | #7 |
50
Rep 573
Dont listen to these guys. You dont have to program or it set it or anything. Just swap out the battery for one ( i paid 100$ for an oem one at a battery store), and continue your everyday life. Thats another bs way for the dealership to make money off you
06-13-2011, 04:29 PM | #8 |
103
Rep 2,783
Where are you getting your information from? Just because you did whatever does not make it right. Have you looked at the Bentley Manual? Do you think BMW and Bentley are conspiring with each other? Have you checked for fault codes? Your car might be throwing codes and you don't even know it. Ah, don't worry about it, close your eyes and do what you want.
06-13-2011, 04:34 PM | #9 | |
103
Rep 2,783
06-13-2011, 04:42 PM | #10 |
175
Rep 1,379
Usually your dealer is a fairly trustworthy source of information. If they say your battery needs to be registered that's legitimate.
With that said you can get them to give you a price break on the registration. BMW suggdests a rip off price to make money but you can get it registered for $30. If you don't register it a bunch of systems will give you low voltage errors, and the battery will be charged too hard. Over charging it may lead to explosions, which at least 1 member has had.
Clean cars are happy cars! CANON PHOTOGRAPHER |
06-13-2011, 04:46 PM | #11 |
Ikea enthusiast
334
Rep 8,140
It's an issue that's been covered in Roundel numerous times, the battery does need to be registered. I'll find the article later.
06-13-2011, 04:54 PM | #12 | |
82
Rep 2,446
4-500$ for this is outrageous. |
06-13-2011, 04:57 PM | #13 |
103
Rep 2,783
I am going to do the same thing, but I will also have it registered either with the BT tool or by an INDY.
06-13-2011, 05:45 PM | #14 |
253
Rep 7,089
Drives: '06 AW 330xi
You don't NEED to register your battery....but if you care about your investment and your charging system, you will.
Registering will prolong the life of your battery. It also takes strain off your alternator because as our cars age, the battery loses it's ability to hold a charge. And the car adapts to that. Not registering a battery will undercharge it....cause it to sulfate over time. And youll need to replace the battery sooner than if you were to register it. Buy your own battery and take it to an Indy...screw the dealer! |
06-13-2011, 06:37 PM | #15 |
Grozniy
177
Rep 2,602
After replacing my battery and not registering or programming it the car started having electrical issues. OP, I would recommend you getting the same spec battery and registering it.
-fatman
06-13-2011, 06:55 PM | #16 | |
127
Rep 6,773
this isnt a honda, guy. |
06-13-2011, 07:09 PM | #17 | |
124
Rep 5,627
If it doesn't play nice with both battery and alternator, electrical system repair costs may greatly exceed the $500 for a properly installed and registered battery. Tom |
06-13-2011, 07:34 PM | #18 |
253
Rep 7,089
06-13-2011, 08:17 PM | #19 |
50
Rep 573
Actually, the reason they make you register the battery is for the battery itself, not the car by any means. The car by default will charge the battery harder than it should (as opposed to less, which they have to avoid). When you register the battery, you ensure that you will get the maximum life out of your battery. This will normally increase the life by maybe 4-5% if you are lucky. So, pay $500 and get an extra few months OR for $500 get 25 years worth of batteries if you plan to keep it long (got a 5 year warranty one for $100)
Im sorry, i could not be happier that i did not register my battery. In fact, when i went to an indy shop to get my tires rotated, he checked my codes and found absolutely nothing. Once again, its foolish to register. And no, your car will not blow up if you dont, stop being ridiculous, were talking about a car that doesnt let you raise the windows with the door open. |
06-13-2011, 08:20 PM | #20 | |
NHTSA Nazi
28
Rep 1,983
The battery will have a much shorter life if not registered. Last edited by ceb; 06-13-2011 at 08:26 PM.. |
06-13-2011, 09:14 PM | #22 | |
253
Rep 7,089
BTW, when your car detects the battery isn't able to hold a charge, it will charge the battery less to put less strain on the car. When your car still thinks it has a battery that isn't able to maintain a charge, it under charges it. Batteries that are discharged, sulfate. This decreases a battery's ability to hold a charge. So you never get a fully charged battery. 4-5%. Nice %'s...where did you get them from? Your ? I won't even give you a % because it's not possible to gauge it..... |
