06-11-2011, 10:37 AM | #1 |
20
Rep 107
Should we "mod" the suspension
I had a Dinan stage 3 suspension on my E46 M3 and thatw as a significant improvement on the road and track.
The reviews I have read have called the 1M stock suspension perfect for road and track Should this car's suspension be replaced as new?.. opinions please...
2011 1M VO | StopTech Trophy BBK | Eisenmann Performance Exhaust | ESS TUne | 3M Protective Coating | CDV Removal | Front Sway Bar | KW Variant 3 Suspension | Vorshlag Camber Plate | Rogue Engineering Short Throw Shifter
06-11-2011, 10:42 AM | #2 | |
4 Star General -Twilight Zone
36
Rep 1,032
Plus, from the sounds of it, this car may be quite the collector car some day... |
06-12-2011, 02:13 PM | #3 |
Not a BMW Insider
13
Rep 302
http://www.1addicts.com/forums/showthread.php?t=540565
Here's a good start for you. "Perfect" for the track is probably not exactly correct, but I think the poster in this other thread is probably pushing it quite a bit harder than most other folks would on a track. Bottom line: if the car is a DD with an occasional track day, it's probably good like it is. If it's your track machine, you'll probably want to upgrade the suspension. |
06-12-2011, 07:42 PM | #4 |
77
Rep 1,421
+1
It's perfect on the street but feels too soft for serious track use. I don't want to lose the street ride but plan on suspension that is a good compromise.
Dan Parker
06-12-2011, 08:00 PM | #5 |
476
Rep 4,153
Drives: 1/18 Monte Carlo Blue E92 M3
Yes get the full M3 suspension from Harold @ HPAutowerks and it turns into a different car.
06-12-2011, 09:19 PM | #6 |
77
Rep 1,376
Drives: 1988 M3, 1990 M3, 1998 M3/4
Garage List 1998 BMW M3/4 [10.00]
2011 BMW M3 Sedan [9.28] 1988 BMW M3 [9.40] 1990 BMW M3 [10.00] 2008 BMW 135i - sold [0.00] 2003 BMW M3 - sold [0.00] |
I totally agree on a 135i. But the 1M already has the full M3 suspension. I think good dampers and higher spring rates would still be a big benefit. Also, you can lower the car so it just looks better, too. Everyone's different, though. Stock is by no means a "bad" setup
1988 BMW M3 - Hennarot/Black
1990 BMW M3 racecar - Diamond Schwarz/Black 1998 BMW M3 - Alpine White/Mulberry 2011 BMW 328i racecar - LeMans Blue/Black |
06-12-2011, 09:28 PM | #7 |
77
Rep 1,421
It does have more pitch, dive, and body roll than I expected but it's by no means excessive. To me, the car gets a lot of it's front end grip from the front suspension travel. Initial turn in has so much bite that you begin to think it will not understeer, but it will at a very high limit. The diff works so well that I found I could minimize the understeer with a little abrupt throttle as soon as the front started giving up and the car would turn neutral to oversteer without delay. It really is a very balanced car that acts as if it really likes it's driver.
Dan Parker
