Wet Footwell
04-01-2007, 08:45 PM | #1 |
85
Rep 2,049
Wet Footwell
Does anyone have any idea what would cause water to enter my passenger side foot well? It has been raining today and my wife got in the passenger seat and noticed the floor mat was soaking wet. The moisture extends to the rear seat area but is confined to the passenger side.
Any ideas would be appreciated.
_____________
1974 2002tii 1978 320i 2007 328i |
04-01-2007, 08:49 PM | #2 |
478
Rep 3,044
Drives: 2011 Dakar Yellow M3, 2018 M5
maybe a poor window seal?
[ESS VT2-625] [Akrapovic Evolution Exhaust] [KW Clubsports] [OSS Angel Eyes] [Revinora r-CRT Lip] [Vorsteiner Boot] [Challenge Race Diffuser] [See the Build Thread HERE] |
04-01-2007, 08:51 PM | #3 |
310
Rep 15,745
sounds like the rubber weatherseal around the door is leaking..either that or the vapor barrier behind the door panel is torn.
Had any work done in there recently?? |
04-01-2007, 11:29 PM | #5 |
119
Rep 1,595
I agree, I had that problem on my 325ci ....bring it to the dealer.
04-01-2007, 11:51 PM | #6 |
Rep 5
My Jetta (06 2.0T FSI) had the exact same problem. It turned out to be two different problems, one leak was caused by water coming though the firewall (when it rains) and the other was a cracked condensor box which is part of the aircon. hope that helps. Regards Dan.
04-02-2007, 07:04 AM | #7 |
129
Rep 579
Can you describe the vapor barrier to me? I'm unfamliar with what this part is.
Instagram: te37sl_m3
04-02-2007, 08:04 AM | #8 |
87
Rep 1,224
I remember seeing another post, 8-10 months ago, with unknown fluid accumulating in the same spot - I think it was water. Don't remember outcome.
Edit - couldn't find it. Last edited by Neurorad; 04-02-2007 at 08:43 AM.. |
04-02-2007, 08:32 AM | #9 |
United States Marine
318
Rep 2,748
the Vapor barrier is a skin behind the door trim panel, which seals door internals. the seal goes bad, or the vapor barrier get's a hole, then water gets in. =)
04-02-2007, 02:12 PM | #10 |
129
Rep 579
Cool, thanks
04-02-2007, 03:03 PM | #11 |
1671
Rep 6,589
Could be the AC stuff too.
I had that issue in my week old (then) VW and the stink from it was forever there after that... Somehow the dripping pipe was clogged (on the bottom of the car) and it "dripped" inside... To add: If that was the window seal, you would probably see some traces of water on your door... Similarly with the vapor barrier. Your water thing should be contained to the carpet only, right? |
04-02-2007, 05:17 PM | #12 |
Smiling politely
165
Rep 7,931
On a lot of cars, a wet footwell on the passenger side means the drainage for the AC is clogged. I don't know about BMW, but this is a relatively common issue on other cars.
E90 330i Black Sapphire 6MT | 991.1 C4 Platinum Silver 7MT
04-02-2007, 09:43 PM | #13 |
Ty Come AGAIN!
9
Rep 350
my c-class had the exact same problem
spent like $350 first time then i notice it was still leaking and brought it bak to the dealer and they charged another $350 i was soooo pissed
2008 E92 335i 6MT Alpine White/ Coral Red, Sports, Premium, Comfort Access, Mtech Angel Eyes, 19" iForged Challenge, Aero Lip, Painted Reflectors, DD SSkirt, Vorsteiner Decklid, Vorsteiner Diffuser
04-02-2007, 10:42 PM | #14 |
1671
Rep 6,589
04-03-2007, 09:45 AM | #15 |
Moderator
618
Rep 10,855
Most likely the vapor seal, as per comments above. This was also an achilles heel on the E46. A/C is less likely as the water is associated with being left outside in the rain. Get this fixed ASAP or your car will end up smelling like a swamp for the rest of its life.
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
06-30-2009, 01:14 PM | #17 |
→сяuisiиg iи му вмш←
66
Rep 1,642
Drives: 2010 Space Gray 328i
Mine had same issue, I am picking it up 2day
SuPerMoD @ MassMonsterz.com
A "Happy" Owner of a Metallic Space Gray 2010 BMW 328i ProGaMeR on the XboX 360 |
