Fog Lights with AE DRL? (No Low-Beam?)
06-08-2011, 03:45 PM | #1 |
SYTFU Crew
36
Rep 1,179
Drives: 2010 Toyota FJ
Thought I had found the value to allow for me to turn on the foglights when only AE DRLs are on with the switch set to Auto without the low-beams coming on. However it didn't work.
Does anyone have some input on this? Would like to be able to roll with just my AE's on with the fogs. Cheers!
06-09-2011, 08:07 AM | #2 | |
That tickles
11
Rep 457
EDIT: Saw you wanted to do this in the Auto position. Just pointing out it can be done manually without coding. |
06-09-2011, 10:44 AM | #3 | |
52
Rep 1,175
06-09-2011, 12:09 PM | #4 |
SYTFU Crew
36
Rep 1,179
Thanks guys but yea I already know about that and have the corner deletes. But I want the functionality of being able to have my fogs on for looks with the DRL but then in low light situations it would turn my headlamps on. Think it would be a really nice little option to have.
06-09-2011, 12:17 PM | #5 |
318
Rep 1,410
Drives: X3 M40i
also interested in doing this
03-15-2012, 11:51 AM | #7 |
201
Rep 3,328
Drives: Coding: Desi4life10@gmail.com
To have foglights on as DRL along with your AE (assuming you have AE set as drl) only, do the following in you NFRM module:
DRL_TFL_MIT_NSW nicht_aktiv --> change to "aktiv" PWM_NSW_TFL wert_01--> change to "wert_02" This way, your fogs turn on as you drl along with your other drl lights (AE). It does not show on your cluster that they are on. When you move the switch to your lowbeams, they shut off (can be toggled one via the foglight button, like before) Last edited by DESI4life10; 03-15-2012 at 11:56 AM.. |
03-16-2012, 01:50 AM | #10 | |
223
Rep 5,120
03-16-2012, 07:35 AM | #11 | |
201
Rep 3,328
There is another line to code if you want them on auto when your lowbeams are on. I believe grant has created a thread regarding that matter. which is right here: http://www.e90post.com/forums/showthread.php?t=614274 Last edited by DESI4life10; 03-16-2012 at 07:50 AM.. |
03-18-2012, 11:58 AM | #12 |
Member
Rep 12
Does anybody know if it is posible to do the same with an old FRM module (FRM1 i assume?).
I can't find anything related to DRL in the trace file. See attached file for reference. Is it possible to get working, or do I need to upgrade to FRM2 or 3 and at the same time have welcome lights and so on? If not exactly clear I want the light switch to stay in the auto position and have angel eyes and my fog lights on when driving at daylight. At night my xenons should automaticly switch on. /Broendbjerg |
03-23-2012, 10:47 AM | #13 | ||
338
Rep 842
2021 G05 X5 ///M50i / Phytonic Blue / Cognac Vernasca
iStep 03/2023.50 |
03-23-2012, 10:55 AM | #14 | |
201
Rep 3,328
I ran this for a week and never had any errors. Might be specific to your car setup then. |
08-12-2013, 11:25 AM | #15 | |
62
Rep 944
Guess its not possible on frm1 ?
03-14-2014, 02:13 PM | #16 |
102
Rep 1,903
Drives: e92 335i 6MT
Bumpity bump to the top we go
I'd also like to know if this is possible on earlier models? I have a 02/2007 e92 335i |
11-30-2015, 01:58 PM | #17 | |
Rep 12
All warning and errors disappear if revert back NFRM config and clear stored errors using INPA. My FRM version is FRM2_E89.C09. Please help! |
11-30-2015, 11:13 PM | #18 | ||
338
Rep 842
iStep 03/2023.50 |
12-01-2015, 04:40 AM | #19 |
Rep 12
I finally managed to escape yellow warning problem and was able to code fog lights as DRL. To do this I disabled all cold/warm checks and now it works as expected (I double checked all light bulbs - everything is ok).
But overall I didn't get what I wanted - I thought fully automatic fog lights will work with LH_UND_NSW_NICHT_GLEICHZ option (front fog lights not simultaneously with flash-to-pass), but it won't |
