F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Latest F30 335i Sedan Spied In and Out. Showing New Wheel Design
Extreme Powerhouse
      06-07-2011, 10:14 AM   #1
Jason
Administrator
Jason's Avatar
Drives: F80 M3
Cool Latest F30 335i Sedan Spied In and Out. Showing New Wheel Design
BIMMERPOST NEWS
89
COMMENTS
Pictured below is the latest sighting of a F30 335i sedan in alpine white. Here's an analysis of the photos.
STYLING
This FEP (final evaluation phase) test mule shows off the F30's sporty/squat design, with its short overhangs and wheels pushed to the corners. The F30 front fascia adopts BMWs current design language, with a sleeker sloping hood with more upright and widened kidney grilles placed below the hood line. As clearly seen in the photos, the F30 will feature double side character lines, the top one which flows directly into the hood and headlights. The rear lights remain classic L-shapes. The side view mirrors will feature turn signals, like the just revealed F20 1-series hatchback. Also revealed clearly for the first time in these photos are additional hood lines along the edge where the camouflage ends on the hood.
Size-wise, the F30 runs on a longer wheelbase and wider track than the current E90 sedan, but with shorter overhangs. It's been suggested before that the F30 is approximately 2 inches longer than the E90.
This test car features new wheels which we've yet to see fitted to the F30. The brakes appear to be fixed piston calipers.
PRE-PRODUCTION INTERIOR
We also bring you new photos of the interior. Along with earlier F30 interior photos, the following features are revealed:
Freestanding Control Display
This is the first F30 interior photo where we can clearly see the same freestanding flatscreen monitor just introduced in the F20 1-series and the current 6-series. The likely display options will be a 6.5 or 8.8-inch high-resolution control display.
Auto Start-Stop
Although the center dash still appears in pre-production form, what appears to be production level is the instrument cluster. The F30's Auto Start/Stop feature can be seen in the tachometer. Additional markings make it easier for the driver to see if the engine on or off due to the Start/Stop fuction -- needle sits at "READY" or "OFF".
Semi Black Panel Display
These photos also offer a good glimpse at the information display in the lower part of the instrument cluster. BMW began implementing black panel display technology with their full black panel displays in the F01 7-series, a feature which will trickle down across the whole model range (as seen in the just revealed F20 1-series). But, as expected, the black panel display is smaller (and partial) in the F30. It isn't a full black panel display -- the markings for the speedometer and tachometer aren't shown via black panel but traditional permanent markings [compare to full black panel display on F10]. Nonetheless, the black panel tech and size of the display used for the on-board computer and other information like radio settings is a vast improvement over the E9x 3-series.
Lane Change Warning System
Finally, this shot confirms that BMW's Lane Change Warning feature will be available for the F30 as well. Sensors at each side of the F30 will continuously check for cars in the left or right hand blindspots. If a car is detected, a small warning triangle in the housings of the exterior mirrors will light up (see photo to the right) and the steering wheel will vibrate.
SCHEDULE / VARIANTS
The F30 3-series sedan is expected to be officially announced in November in London, in connection with the upcoming 2012 Olympics, and makes its world debut at the 2012 Geneva motor show in March of 2012. Sales should begin shortly after in Europe and in the US by the Spring. As per the usual 3-series sedan/coupe timeline, the F32 coupe should debut a year later sometime in 2013.
An Active Hybrid F30 3-series as a Concept will also be shown at Geneva and there is also a 3-series GT (Gran Turismo) which has already been spied in testing.
Expect engine options to include a full range of turbo engines. The 28i will likely be powered by the same N20 turbo 4-cylinder powering the X1 xDrive28i and the upcoming Z4 sDrive28i, and the F30 335i will again be powered by a turbo 6-cylinder engine.
Follow all our F30 3-series coverage at http://www.bimmerpost.com/3-series/f30/
      06-09-2011, 02:55 PM   #2
SamS
Drives: Tesla M3 Perf + '18 X3 M40i
Those wheels look great! Probably 18", but they look almost like a 19" with those low profile tires.
I am still not digging the "pop up" style nav screen. Seems like it is just arbitrarily stuck there, not nicely integrated like on current E9x cars.
      06-09-2011, 02:57 PM   #3
E39hijinks
E39hijinks's Avatar
70
Drives: 2016 Lexus
wow very revealing shots! awesome! that side shot makes me like the F3x soooo much more
also anybody notice the calipers? 6 piston?!
      06-09-2011, 03:05 PM   #4
shanecarmaster1
shanecarmaster1's Avatar
Drives: e90 325i, F01 750Li, e38 740i
It better not do what the 1-series did.
A BMW can be described in one simple, yet true statement, "From the outside you don't understand, from the inside you can't explain." How true is THAT?!
      06-09-2011, 03:10 PM   #5
assinizarM3
Drives: bmw e70 4.8 - 02 530 manual -
That nav screen is hyundai'sh interior is still boring and surprisingly far away from the 5's interior! Exterior is looking good so far!
      06-09-2011, 03:12 PM   #6
twin fed
Doc Brown
twin fed's Avatar
1176
Drives: 2016 MG MT M2
I am pretty sure that it is a 4 piston.
      06-09-2011, 03:12 PM   #7
E31BMW
E31BMW's Avatar
Drives: Cars!
i hate the auto shifter, hate the dash and simple style layout. the screen is garbage, but i do think the exterior will be less of a disappointment. I will be selling my 335 pretty soon and moving onto the GTR. not liking where BMW is headed.
      06-09-2011, 03:17 PM   #8
antzcrashing
antzcrashing's Avatar
Drives: 2018 BMW 440i GC
looks sick
      06-09-2011, 03:19 PM   #9
shanecarmaster1
And might I add that that interior is God awful. I'll keep my e90.
      06-09-2011, 03:19 PM   #10
yakev724
yakev724's Avatar
231
Drives: 15 S3
"let's leave the head/taillights non-LED to give us something to update for the LCI"
After 3 generations, I think it's time to grow up.
      06-09-2011, 03:27 PM   #11
southlight
Moderator / European Editor
southlight's Avatar
1494
Drives: X3M
Saying this based on spyshots = bad idea
Best regads,
south
Those forums...WHY NOT?
JOIN THE 6MT CLUB GROUP
      06-09-2011, 03:44 PM   #12
TheBingoBalls
TheBingoBalls's Avatar
3817
Drives: BMW
The render makes the F30 look rubbish (because the front end vs. the rest of the car is extremely off) but the spy shots make it look great! Definitely looks like it's going to look like a mini 5er.
      06-09-2011, 03:48 PM   #13
gun6slinger9
28
Drives: 428xi
I very clearly see a 6mt but maybe i'm just seeing things?
      06-09-2011, 03:54 PM   #14
Touring
Touring's Avatar
Norway
178
Drives: i3,E21,M2,E23, Skoda Kodiaq
My next car
      06-09-2011, 03:59 PM   #15
TheBingoBalls
3817
Drives: BMW
Originally Posted by Touring View Post
My next car
Yup! By the time the fleet of F30's are finally in production, I expect my E90 325 to be on its way out... LOL
      06-09-2011, 03:59 PM   #16
DDS2015
392
Drives: 2018 M3CS
2021 BMW X3  [0.00]
2023 BMW M4  [0.00]
I saw a 6mt in the first few pics also. Makes me a little more excited. Also I dunno if it's the wheels or what, but this mule looks really good IMO. Also, I like the free standing nav unit. As long as it's integrated well like on the new 6er then it'll be good.
I really hope that they don't screw up the front though, that would be a disappointment.
      06-09-2011, 04:29 PM   #17
BimmerGuyFL
Drives: 2013 F10 BMW 535i M-sport
Originally Posted by F25X3 View Post
too big and if it has electric power steering too dull to drive ala X3.
+1
2013 F10 BMW 535i Alpine White / Oyster Dakota Leather / Anthracite Wood Trim / Steptronic transmission / M Sport Package / Premium Package / Technology Package / Rear-view camera / Park Distance Control
      06-09-2011, 04:42 PM   #18
LemonOne
LemonOne's Avatar
Drives: ///Most Powerful Letter
Really? same interior as the F20?
What happened to the driver-oriented cockpit?
Man.. what is BMW doing these days...
      06-09-2011, 04:44 PM   #19
BMWFreaky
BMWFreaky's Avatar
Spain
64
Drives: E90 320D
The interior is very disappointing, it's a copy of the F20 interior and not similar to the F10 interior like scott26 told us
Originally Posted by SCOTT26 View Post
That is the "Unfinished" F20 1er dashboard in that 3er, the 1er gets the option of a flat screen monitor that sits at the top of the dash , similar to the BMW 6er Coupe and Convertible.
I really don't like this interior it's not premium enough like the F10 5series of new 6series
      06-09-2011, 05:01 PM   #20
IancoleTX
Dillo boxers
IancoleTX's Avatar
Drives: 2019 M5C
Dude you guys can't even see the interior, what are you talking about lol.
The exterior shots are looking surprisingly promising. Profile especially.. yum
2019 M5C Matte MBB / Tartufo
      06-09-2011, 05:02 PM   #21
bmrm396
Drives: 2018 F80 M3cs
My next car
i thought so as well, but the more and more i see the more dissapointed and utterly fiuckin confused i am about what BMW is doing ... seriously, its like theyre confused about themselves
Formerly addicted to e46fanatics
Formerly addicted to e90post
      06-09-2011, 05:30 PM   #22
OdomPHD
I break for no one
OdomPHD's Avatar
Drives: e9o "Vanity 2"
I PRAY they'll offer the LED headlight/tailight as an upgradeable option. At this date in time, unloading 45k USD on a set of four wheels and an engine MUST include LED lights. I mean, c'mon guys. wtf. You seen a non HID caddy driving around here lately? Not where I am, they're all HID... As should all luxury brands be.
Just not BMW. Make sense??..
Tags
2012 3-series, 2012 3-series sedan, 2012 335i, 2012 bmw 3-series, 2013 3-series, 2013 3-series sedan, 2013 335i, 2013 bmw 3-series, 2014 bmw m3, 2014 m3, 3 series f30, 335i f30, 335i forum, 335i forums, bmw 335i f30, bmw 335i forum, bmw 335i forums, bmw f30, bmw f30 3-series, bmw f30 328i, bmw f30 335i, bmw f30 forum, bmw f30 forums, f30 335i
f30post
