06-02-2011, 08:48 PM | #1 |
48
Rep 1,038
Computer won't do boot up...
So my gf claims it was fine when she went to eat then came back to it & it would not come back on.
It turns on, but does nothing. I get absolutely nothing on the monitor. I swapped monitors to rule that out. I know its not booting to windows b/c I do not get the standard audio when windows boots. I reset the PC 50 times, I removed & reinserted the video card, etc. Still nothing. |
06-02-2011, 09:07 PM | #5 |
Fapmin
402
Rep 2,660
06-02-2011, 09:14 PM | #7 |
21
Rep 176
Any beeping going on? Motherboard lights coming on? If fans are spinning and lights are on then the PSU is probably ok. Next step is to start pulling 100% unnecessary parts.
If you have 2 sticks of RAM pull 1 and try it with that, if still no luck then try the other one alone. Unplug the hard drive and disc drive. Reset the BIOs using the motherboard jumpers or reset button(you'll have to check your manual because each board is different) Try a different video card. Preferably something with a different interface than what you are using currently. |
06-02-2011, 09:22 PM | #8 | |
Careful, I Bite.....
153
Rep 504
Nope. Some computers need pairs of RAM to work. |
06-02-2011, 09:27 PM | #9 |
21
Rep 176
Doesn't matter if it works or not. If a stick of RAM has gone completely bad the BIOs might not even show a POST message. If you remove the bad stick you have a very good chance of at least seeing a message saying something in the POST.
Right now you should be trying to isolate the issue, not solve it yet. |
06-02-2011, 09:31 PM | #10 | |
48
Rep 1,038
06-02-2011, 09:43 PM | #12 |
34
Rep 407
Try making sure that nothing is loose inside. Also, if you have any spare parts, try swapping things in and out to rule stuff out. Otherwise you may need to take it to a repair shop or somewhere they would have enough spare parts to diagnose the problem.
Not true at all, you can easily run with 1 stick of RAM. It won't run as fast as before, but it will run. |
06-02-2011, 09:52 PM | #13 | |
137
Rep 337
Never-Enough, Sometimes your food isn't made on time, you get hungry, and you overlook statements, so I will quote this for you. This is a serious statement that warrants your immediate attention.
You will never be as complex as the strand of hair sitting on top of your head.
06-02-2011, 09:56 PM | #14 |
Crazy Russian Bastard
30
Rep 819
If the RAM checks out OK, then Its either the VGA or the Mobo gone bad.
So if her PC is just a cheap Dell, it would be better she buys a new one.
B
M W |
06-02-2011, 10:20 PM | #18 | |
153
Rep 504
Hard drive? No. You'd still see the BIOS screens on the monitor. Graphics card? No. You'd hear the POST beep. RAM? Probably not. Motherboard? My guess. PSU? Also a possibility, if one voltage died, you'd still see some lights. |
06-02-2011, 10:42 PM | #19 | |
you know he kills little girls like you
388
Rep 892
I was joking. TBH, I don't really care, I was just attempting to make humor out of the myriad different suggestions. I don't know anything about computers anyhow. |
06-02-2011, 10:49 PM | #20 |
734
Rep 3,274
It's really weird, but sometimes computers can do that because they just store too much shit on their hard drive and the windows startup can't load properly because of some tiny discrepancy in what's written onto the drive.
If you can actually get the computer to start up again, it's easy to fix to prevent it from happening again. Anyone can do this on their computers to prevent something similar from happening. All you have to do is go into your C:/Windows folder, and find the folder in that called "system 32" and just delete it, then restart. This will clear out all the temporary junk files you don't need any more, but windows keeps anyway. Try it out
2022 X4 M40i - 2008 135i - 2015 F700GS On Order - 2024 i4 M50 Scruffy's gonna die the way he lived... Mmhm. |
06-02-2011, 10:50 PM | #21 | ||
153
Rep 504
Two reasons to not ask for computer advice on a car forum. |
06-02-2011, 10:55 PM | #22 |
734
Rep 3,274
shhhhh!
Tags |
lol @ u experts |
