Question about agressive/stretched setup for 19" LM rep
05-20-2011, 07:35 AM | #1 |
213
Rep 2,602
So I just picked up a set of LM reps and wanted to run as aggressive as possible. Offsets are 35/37 with 8.5" in front and a 9.5" rear.
I want to run a stretched setup - 225 or 235 front and 255 rear. I will also be running spacers. Any idea on the max size spacers I should get? Thanks! |
05-20-2011, 10:12 AM | #2 |
Rep 55
I'm running 8.5 20 with 215/35/19 and 9.5 21 with a 15mm spacer so 6 with 225/35/19. Lowered on kw all the way down on the rear and slammed on the fronts. My rears rubs alittle on hard dips. I just my fenders than everything will be fine.
05-20-2011, 02:01 PM | #5 |
BimmerPost Supporting Vendor
2048
Rep 25,989
For a stretched setup on the widths/offsets you have, you'll probably want to run a 225/255 setup for a slight stretch.
-Charles@VMRWheels
VMR|Wheels | 714.442.7916 |
05-20-2011, 02:20 PM | #7 |
89
Rep 3,355
Drives: VIP Sport 335!
roll your rear fender and you can run a 10mm spacer. if not, 5mm is what you can do. if you do get slight rub with spacers, you can do some camber.
07 E92 335!
AA AE GP HR LC M3 KW BMS BMW LUX CYBA STRI WORK HELIX MTECH LSWEEE(Wavetrac)! |
