Need help changing the Vehicle Order (VO)
05-18-2011, 11:35 PM | #1 |
Rep 15
I'm trying to add VO $522 for xenons. I followed the PDF guide to add the option and write it to CAS. Then the instructions say "the 2nd control unit which stores the vehicle order must now be coded with the new vehicle order".
Which item do I select in the list for the 2nd control unit? This is a 2008 328i. Thanks! |
05-21-2011, 08:15 PM | #9 | |
Rep 15
After coding the car, i'm still sometimes getting a lower bulb out error when I start the car. I just coded out the cold start lower bulb check, so I hope that solves all errors. I also did the corner delete and made the LED angel eyes my DRL's. Looks awesome. |
05-28-2011, 05:34 PM | #12 | |
118
Rep 1,002
Don't want to brick it here but you have kindly offered your assistance and I will definitely contact you when the parts arrive |
