Buzzing Sound Form Rear of Car
03-26-2007, 01:15 PM | #1 |
1013
Rep 1,268
Has anyone heard a buzzing/humming sound coming from the rear of the 355i after the car has been turned off. I've heard the sound a few times it does not show up all the time. you can hear it if you bend over near the rear wheels. It sound like a small motor is running. I was wondering if it was the gas pump, which I am assuming it is in the gas tank.
It is not very loud, and I hear most often in my gargage with minimal background noise. I know it is not the turbo spinning down, I know what that sounds like, this sounds more electric. After a few minutes it stops. Last edited by Maestro; 03-28-2007 at 08:30 AM.. |
03-26-2007, 02:17 PM | #2 | |
Trance Life
315
Rep 4,706
This noise sounded different, though, kind of like it was a bit out of line. It might have something to do with the fuel pump although it could be anything. |
03-26-2007, 05:18 PM | #6 |
10
Rep 170
Same thing here about 3 weeks ago - low tone buzz for about 20~25 seconds from right near the filler access door.
I guessed it was the fuel pump or fuel return running, but thought it odd that I had never heard it before... |
03-26-2007, 08:38 PM | #7 |
Perf BMW mag issue 147, 159
414
Rep 6,803
Its the DMTL pump running a tank leakage test... its normal...
'13 Estoril Blue 335i M-sport
*Don't PM me!* Message me here- http://www.facebook.com/ProjectEstoril |
EFk0.00 |
03-26-2007, 11:19 PM | #8 | |
1013
Rep 1,268
But why would this do this test after you shut the car off. I think I have a problem that things are still on and running after the car has been turned off... call me old fashion this does not see right. Ok, maybe the reason I do not hear it all the time is that it seems more noticeable on a low tank, more space to fill. Last edited by Maestro; 03-27-2007 at 12:22 PM.. |
03-27-2007, 11:40 AM | #9 | |
37
Rep 1,165
03-27-2007, 06:06 PM | #10 |
19
Rep 482
There's also a fan that cools the amp for the stereo, that's on the left side of the trunk. That too will run for a bit after the car is shut off.
03-27-2007, 06:45 PM | #11 | ||
Rep 58
I would think it needs to pressure test the tank with the fuel pump off so it isn't losing any pressure through fuel being pumped out.
03-27-2007, 07:36 PM | #12 |
216
Rep 1,794
Drives: 06' E90 330, 20' F97 X3m
i think u guys are talking about the fan on the stock amp. it stays on for a while till the radio goes to sleep. next time it happens, open the trunk and remove the plastic cover on the amp.
LIVE FAST..DRIVE FASTER!! |
03-28-2007, 09:03 PM | #13 | |
414
Rep 6,803
lol its all good man... i just happen to be a tech so its no big deal... imo, its better to inform u guys about things like this rather than having customer bring it into the shop and waste their/my time...... the car cant run the tank leakage test with the car running so it does it everynow and then when you shut the car off... weird but true.. just like sometimes the electric fan will run when the car is shut off... if you have a 335i you might even hear the water pump running to circulate the coolant through the turbo's so they dont overheat themselves
03-29-2007, 08:58 AM | #15 | |
1013
Rep 1,268
Yeah, I had other cars that the fan ran for a few minutes after the car shut off and that too bothered me. It tells me that the car was poorly design, it was like it was barely keeping itself cool. Those were not performance cars and I can see a performance car needing continue cooling after shut down. I did not think it was the fan on the power amp since it makes no sense because as soon as you turn off the power the amp would begin to cool down. Unlike an engine which the cylinder are still much hotter than the rest of the engine and might still need water circulating to bring their temp down. |
06-22-2007, 09:17 PM | #16 |
king of the hills
92
Rep 2,915
Drives: 2011 M3 w/ESS55, 2001 540i/6
I actually had my DMTL pump fail the other day. Got the "Service Engine Soon" warning lamp, brought it in and they said it was the DMTL pump. I had no idea the car had a pump just for diagnostics, crazy stuff.
