Delaminating Headlamps 2006 E90
05-16-2011, 04:25 PM | #1 |
Race It All
Rep 18
Contemplating replacing my headlamp assembly. Lots of pitting & the top of both assemblies is delaminating. J Levi Street Works has a complete projector set, but unsure if my Factory Adaptive Xenon set-up will mesh. Considered the painted "Brow" idea, but that just covers the issue. Don't think the "Headlight Restore" is going to address the delaminating issue. Any success stories???
So Cal Smoke Eater
05-16-2011, 04:44 PM | #2 |
261
Rep 1,794
Drives: F30 328i M 6mt, E36 M3
I had a similar issue with mine.
I took some very fine sandpaper and wet sanded them. Then I took a small air driven buffer and small wheel and used an agressive polish, then a medium polish, then a fine polish. After all that, my headlights look pretty damn good.
05-16-2011, 04:44 PM | #3 |
231
Rep 3,561
Not sure what you mean by 'delamination' but if it's surface damage, buy the 3M kit for $20 and do your best. Tape everything off and follow instructions closely. The key is to take your time to be 100% sure each stage has done it's job completely.
Once you're done, the largest pits won't come out, but nearly all should. Any surface imperfection/cloudiness/etc. should all come out since it should all be contained in a small layer of the plastic. 1 or 2 more fine polishing steps (with a rotary) to get them as close to perfect as they can get, but this is by no means required. Don't get non-OEM replacements. Replacement housings to which you can transfer all your parts go for $600-700 so worst case, do that. You should be able to get a solid 200-300 out of yours if you go that route as well. |
