Half Engine Light??
05-16-2011, 02:13 PM | #1 |
121
Rep 774
Half Engine Light??
Driving on the freeway car, got the half engine light, loss of power, turned the car off and on, no engine light but the car feels slow, like no boost is kicking. On the way home got it scanned from shop, with just a generic scanner, no codes popped up.
05-16-2011, 03:32 PM | #5 |
153
Rep 3,730
First off, generic scanner sucks butt, a BT tool is well worth it's weight in gold. Most likely HPFP, but could be just about anything without a proper scan. Injectors, Vanos, boost leak, blown turbo, ..... you get the point. Take out your mods and get is to a dealer.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
05-16-2011, 04:07 PM | #6 |
121
Rep 774
thanks guys, dealership just replaced the hpfp about 2 weeks ago because of this stupid recall, car was fine before that stupid shit. Anyone near my area have a scanner that I can use???
Car is STOCK |
05-16-2011, 04:37 PM | #7 |
149
Rep 3,552
usually BT Scanners are vin locked unless someone has a profession version(unlimited vins) bt scanners are a 1 time use or 3 vin locked(only can read 3 cars)
05-16-2011, 05:06 PM | #8 |
147
Rep 2,383
The half engine light merely means you are driving a 335i with a high pressure fuel pump. Nothing to worry about, completely normal, move along.
Speakers: CDT Audio HD-42 comps--front doors (RAAMmat deadened), CDT ES-06 6.5" woofers--kickpanl Pods, Hertz EBX202R dual 8" ported trunk sub. Amps: Phoenix Gold RSd 500.4 (comps & pods). PG RSd 600.1 (sub). Power & Ground: 4AWG Streetwires w/RockFosgt RFDB1 distro blocks. Input: HU lineout--Kicker KISL RCA adapters--RockFosgt RFIT-6 cables--Audiocontrol Matrix--Monster cables--RSd 500.4--lineout Monstr Cabl to RSd 600.1.
05-16-2011, 05:56 PM | #9 |
165
Rep 7,433
at speeds no higher than 40
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
05-16-2011, 06:55 PM | #11 |
121
Rep 774
I was driving normally on the freeway at 77 mph, and out of no where i get the charm noise and I thought i was low on gas, but the center console had a engine that was half colored, and at the same time the power was reduced. Then i get on a off ramp, turned the car off, turned it back on, the light went away, but still seems to drive under powered. No strange noises either
