For those of you that used Lamin-x on your taillights
05-15-2011, 02:12 PM | #1 |
Rep 81
How many bubbles did you have when you were finished? How long did they take to go away? Did they go away completelyl?
05-15-2011, 04:20 PM | #4 |
Rep 81
Really? Either you're really good at installing it or I'm just terrible. I have quite a few bubbles and had a hell of a time with the install. The video I watched stated that the material is breathable and that the bubbles should come out with a few weeks of heat and sunlight. Hopefully that's the case.
05-15-2011, 06:16 PM | #6 |
Bavarian Fever
34
Rep 1,108
No bubbles at all. I went with the "smoked" look.
| ESS n52 Tune | BMW Performance Intake/Exhaust | LUX H8 v3 AE | GP Thunder 8500K fogs/corners | LED: signals/interior | V1 hardwired | debadge | AC pedals | Performance shift knob/boot | CF e-brake | Aero lip | m3 side skirts/spoiler | MB kidneys | Strut brace | Painted reflectors | Painted Calipers/Hubs | 35% 3M tint | Smoked tails | CF Roundels | 19" Miro 942 | Conti DWS | H&R Springs for xi | Bilstein Shocks| Nxt: Alpine Subs/Amps
05-15-2011, 06:22 PM | #7 |
¡Viva España!
373
Rep 7,803
You need to use soapy(baby shampoo) water in a spray bottle and squeegee.
Take your time and it should come out perfect.
23 G42 230i Mineral White Cognac, Aluminum With Mesh Effect Interior Trim MODS Clear Guard, 15% Ceramic Tint, Floating Caps
05-15-2011, 09:00 PM | #8 |
Rep 81
I didnt know you should use soapy water. The bottle that comes with the lamin-x kit was empty so I just used filtered water. I went with the smoked look but I have quite a few bubbles in mine.
05-15-2011, 09:29 PM | #9 |
¡Viva España!
373
Rep 7,803
Yeah, same as the clear-guard. Some of the bubbles might go away with the heat from sun, but I would have to see what they looked like.
05-15-2011, 09:55 PM | #10 |
11
Rep 270
i used a paint called night shades from Pep boys, spray 2 light coats for a smoked looked 3 coats for a dark look, you can actually take the paint off if you want with a cloth with acetone or alcohol if you end up not liking, no bubbles took like 10 mins.
2008 335XI BLUE
05-16-2011, 03:52 AM | #11 |
No 55mph
1622
Rep 8,476
Used Light Smoke Laminex on my tails - no bubbles.
I practiced 1st with light smoke on my fogs, then clear on headlights, tails last. Did have a couple tiny bubbles on the one headlight (appeared to be from the soapy water solution I used - they came out on their own after about 2 weeks in the sun as they state. I did use plenty of soapy water solution misted on headlight and reverse side of film when applying. Some times, if you have large bubble you can't get out, you can simply prick the center of the bubble with a needle or pin - then squeegee over the bubble to force the trapped air out thru the pin hole. Laminex film should self heal the pin prick as long as you don't overdo it...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
05-16-2011, 02:09 PM | #12 | |
Rep 81
