Sunroof won't close!
05-14-2011, 03:54 PM | #1 |
16
Rep 103
My sunroof on my e92 won't close all the way. It leaves a few inches open but other than that the glass moves smoothly, but don't know what could be the problem, anyone else have this problem? What could be wrong?
Thanks!
'09 335i Coupe
Exterior: Black Sapphire Metallic Interior: Black Dakota|Trim: Dark Burl Walnut Premium|Sports|Navi|HD Radio|Logic 7|iPod |
05-14-2011, 04:19 PM | #2 |
165
Rep 7,433
You can try doing a reset on the sunroof: Press the 'tilt up' button, wait for sunroof to rise, continue to hold it, the sunroof will rise another 1/2", continue to hold the button, sunroof will go through the entire open and close sequence.
If that doesn't fix it, you'll probably have to go to the dealer.
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
05-14-2011, 04:22 PM | #3 |
My other ride is a Bianchi Infinito
96
Rep 2,767
I just had a problem like that on Thursday. Got a warning light on my dash and my moonroof wouldn't close. I held the center button for 1 minute let it do all it's motions and everything went back to normal.
05-14-2011, 04:30 PM | #4 |
16
Rep 103
Thanks friends! Will give it a try!
'09 335i Coupe
05-14-2011, 05:30 PM | #5 |
88
Rep 1,404
If pressing the button method does not work, there's a manual or cranking method to close the sunroof also. Give us a report to how's it going on your end.
Name: Blanca | 07 E92 | AW-Blk | ZSP | Alcon BBK | M3 Bits | VM RR Links | Koni | UUC Sways | V5 | Dinan CAI | ETS IC | Fge DV | ER CP | Cyba | Raden. Exh | Mod Step | Trunk Drawer | Perf LED Wheel | Illum Dr Sills | IS Shifter | Parrot | Philps D1S | 6000k fog | MTECH RR | CSL Trunk | Aero | Roof Spoiler | PSS on BBS RS-GT 19s
05-14-2011, 06:03 PM | #6 |
253
Rep 7,089
Drives: '06 AW 330xi
OP, didn't mention that the sunroof moves in small increments....which indicates it doesn't need to be re-initialized.
Have you checked the tracks? Make sure nothing is there. I had a friend who couldn't close his sunroof. I found an acorn in one of the tracks and it prevented the sunroof from closing all the way. |
05-15-2011, 12:04 AM | #7 |
73
Rep 1,770
05-15-2011, 01:27 AM | #9 |
16
Rep 103
Worked like a charm thanks y'all
'09 335i Coupe
05-15-2011, 05:22 PM | #11 |
96
Rep 2,767
05-15-2011, 05:39 PM | #12 |
88
Rep 1,404
x2
07-06-2012, 02:20 PM | #13 | |
41
Rep 592
+100 Just worked for me Car must be running I believe during reset
2011 335i Space Grey Msport E90
BMW Performance Exhaust PPK Stage I Lux H8 , HID Fog lights 5k |
07-06-2012, 03:15 PM | #14 |
57
Rep 503
Drives: e92
BMW doesn't include said crank anymore =([/QUOTE]
can we buy crank from bmw? it always bothered me having that empty slot in the trunks tool kit, and it does talk about the crank in the manual.
ZSP/ZPP/BMW PE&PI/ BMW CF STRUT BRACE/ EIBACH PRO SYSTEM / H&R WHEEL SPACERS
06-16-2013, 01:32 PM | #17 |
Rep 156
Thanks guys! my sunroof was not quite all the way up in the fully closed position. back edge lower than roof by about an 1/8 of an inch. problem solved. Ignition must be on to do this.
01-29-2016, 04:20 PM | #20 |
17
Rep 181
Thank you my forum genius'! You saved my anxiety attack that's been happening for the last two months of seeing a 1/4" gap from flush and just coming out of warranty! All I saw were huge $$$$ when thinking of getting this fixed!
This reset has worked flawlessly!🙏🏻 Does anyone know why the calibration would have been thrown out initially??? |
01-29-2016, 04:31 PM | #21 |
No 55mph
1622
Rep 8,476
can we buy crank from bmw? it always bothered me having that empty slot in the trunks tool kit, and it does talk about the crank in the manual.[/QUOTE] Yes you can buy the crank from BMW One of the 1st little items I bought
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
01-29-2016, 06:32 PM | #22 |
57
Rep 503
Drives: e92
