vibrations even after replacing rotors, pads, tires, discs...
05-13-2011, 12:58 PM | #1 |
Rep 23
Hello,
I have e91, 09/2005 Recently problem with vibrations under braking growed so I visited dealer, he said its front rotors, after replacing them problem seemed to be gone. After 5000km, its with new rotors, pads and aligned tires its growing again, its very sad cos i really dont know what could cause these problems. Vibrations occurs under almost any speed, from light pedal press, seems to be not as significant if i rotate steer wheel while braking or do very hard braking. Both front tires seems firm, no slackness. Are new rotors screwed again? Hope not, they with pads together costed me 500EUR, gee.. Any advice would be way more than helpful |
05-13-2011, 01:09 PM | #3 | |
Rep 23
It happens only if i brake Tires are Gooed Year Excellence 7000km on them |
05-13-2011, 01:14 PM | #4 |
pull my finger to get your kinder® surprise
148
Rep 10,455
maybe it's your braking habit? Do you do a lot of hard braking?
Sounds like the problem was fixed when you got new rotors and pads, and now it's coming back again.
05-13-2011, 01:25 PM | #5 |
Rep 291
Drives: 2008 328i, with 3 pedals
Hi,
Vibration under braking is often related to worn thrust arm bushings. These are also called lower control arms. Odd to see this at 5000 km, however. Check those for wear/damage. Regards |
05-13-2011, 01:37 PM | #6 |
377
Rep 2,982
yea, check the front suspension linkage. The fcabs are probably cracked and have some play. The braking force moves from pad on metal to the lower arm joint where the metal sticks into the bushing. It it's not snug, the arm will vibrate a lot in there, giving your entire car a lot of shake.
05-13-2011, 01:47 PM | #7 |
Rep 23
nop car has 270k km, i said 5k after replaced rotors/pads problems starting to occuring again
05-13-2011, 01:49 PM | #8 |
Rep 23
nothing significant original parts for 500eur shouldnt withstand for 5000km, pretty standard highway kms, with not single ABSenabler encounter..
05-13-2011, 01:54 PM | #9 | |
Rep 23
is FCAB linked with control arms bushings other post, or FCAB mean "front control arm bushing" me idiot hehe... Shouldnt FCAB show some looseness on tire when on lever? We checked that and seemed to be firm. Btw dealers here in Slovakia are pretty much clueless |
05-13-2011, 02:01 PM | #10 |
25
Rep 691
if there was no vibration right after you replace the rotor pads etc... and it reoccurred after 5000KM, maybe your caliper is bad, it got sticky and ruined your new rotor? it may be possible to have the dealer check your caliper to see if it's bad, could be a stick cylinder? you may be able to savage the rotor just by turning it.
05-13-2011, 02:17 PM | #11 |
231
Rep 3,561
look into the hub bearings as well...no experience with how long the last on BMWs, but I've replaced them on at around 150k miles on 2 previous cars. Symptoms are pretty much exactly as you describe. Usually with braking, vibrations increase in amplitude as you brake harder, bearings do not share this effect.
05-13-2011, 02:39 PM | #12 |
Rep 23
thanks for replies guys, i understand all but "hub bearings" sorry my tech english isnt good enough, could you please explain? part number or some else hint?
i ll check these all with dealer in monday |
05-13-2011, 02:42 PM | #13 |
Rep 23
got even hub bearning thanks so far, so priority for me:
1.) fcabs 2.) calipers, cylinders 3.) hub bearings lets hope its not all of them, btw both rear wheels has some looseness in vertical axis but that shouldnt cause problem i guess |
05-13-2011, 02:43 PM | #14 |
231
Rep 3,561
#5 Below. This is the whole wheel hub with the bearing inside. It's a pretty expensive part so yours should be tested before just replacing it. Sometimes it's possible to replace the bearing only (and re-use the hub assembly), but I do not know if it is possible on our cars. Good luck
05-13-2011, 02:55 PM | #15 |
Rep 23
i guess it wont be hub bearing hopefully, cos it would vibrate more likely not only during braking and would maybe make some huuu sound?, just picking up every possible thing
05-13-2011, 03:36 PM | #16 |
Been there, wrecked that.
18
Rep 547
You have 270K km (168K miles) on your car?
It is your control arm bushings. Generally, bushings have degraded and are leaking fluid by 145k km. I had the exact same problem as you. I thought it was the new brakes I had recently installed. Brakes/rotors were absolutely fine. So, took the opportunity to replace the controls arms with E9X M3 units. Car steers better than when new and no front end vibrations with or without brakes. I recently replaced the OEM struts/shocks with Koni FSDs. At 240K km, the hub and hub bearings were fine. An area where BMW didn't skimp on quality/engineering. It's your control arms. #9 (BMW calls them tension struts), with your mileage, you should also change #14 (wishbones) if you can.
-Brian
~199K miles. I -still- don't fear my 335i. Last edited by Bcube; 05-13-2011 at 03:49 PM.. |
05-13-2011, 04:14 PM | #17 | |
Rep 291
If you have 270k on your car, I'm almost certain it's your thrust arm bushings. They have lasted longer than average and the symptoms you describe are classic. Regards |
05-13-2011, 04:46 PM | #18 |
Rep 23
yep thats correct milleage, i have car for 2 year made last 100k km myself
car is great otherwise, just had some problems with passenger foot module blowed circuits after oxidated contact in 5th door light (had to be replaced), otherwise no problem at all Last edited by mathewst; 05-13-2011 at 04:52 PM.. |
05-13-2011, 04:48 PM | #19 |
Rep 23
05-13-2011, 05:18 PM | #20 |
Rep 291
05-13-2011, 11:47 PM | #21 | |
38
Rep 715
Given the miles (KM's) and the recurrence of the problem, it sounds like you need to have the suspension checked out soon by a suspension expert. It would be best to find a BWM suspension expert, but any suspension expert should be able to find the problem. |
05-14-2011, 04:18 AM | #22 | |
Rep 23
Tags |
vibrations braking |
