Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > E92 "No Radio" Coding?
      05-13-2011, 09:57 AM   #1
ksharpe1
United Kingdom
Drives: 325d Sports Coupe
Can anyone help ???
Is it possible to code E92 2011 models with the a "No Radio" option , I would have thought it would NOT be an option since the PDC & GONG warnings are generated via the standard radio.
I have heard of people coding out the radio but is this on models where the warnings are produced in a different way?.
After fitting a Pioneer F30BT unit I am presently having to refit the standard radio in the boot to bring back these audible warnings.
Any help in solving this question would be appreciated.
      05-15-2011, 02:55 PM   #2
jelly
United Kingdom
Drives: ASTRA COUPE TURBO
You can code out radio. Warning/gong is then taken over by the cluster.
This can be done at the dealer or with autologic.
      05-16-2011, 02:10 PM   #3
ksharpe1
United Kingdom
Thanks for the reply but can you explain a little more???
If this is the case , I can't understand why the standard work around when fitting a double din unit is to mount the standard radio in the boot, wiring in power, can-bus and a couple of speaker wires fed back to the dash for an additional speaker.
Your method would appear a lot neater and a lot less bother.
