TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > AE and Sunroof question
      05-13-2011, 12:24 AM   #1
Motastic
Motastic's Avatar
Drives: E92 335!
Hey,
I just installed my camarro's AE' and fog lights and they look good BUT the question is that when I turn on the car, they flicker just a tad bit as in like even they lit. Its not consistent power sorta. You cant really tell but I can notice it and bugs me. Do I need to up the volts on it or anything or just deal with it
second of all, two weeks ago or so. Coded the car to where I can roll the windows back up and close sun room, but ever since than when I close sun roof it vents it half way. The car thinks that the closed position. What can be done in that instance.
Thanks,
Mo
      05-13-2011, 01:55 AM   #2
1QuikWS6
No 55mph
1QuikWS6's Avatar
1616
Drives: F32 435ix MSport
As for the sunroof - try the Sunroof Initialization Procedure:
  • Insert key fob and turn the car ON - don't start it - push the start button with your foot OFF the brake/clutch
  • Next, push and HOLD the sunroof button up (vent position). After about 15-20 seconds, the sunroof will vent. CONTINUE HOLDING THE BUTTON UP. After another couple of seconds, 15 or so (might feel long, but keep holding), the sunroof will close, the open completely, then close completely.
  • Once the sunroof has closed completely, the process is over. It's important that you DO NOT let go of the button while the sunroof is going thru the initialization procedure.
  • You might get warnings on I-Drive or the on-board-computer, but that is normal during this initialization...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
      05-13-2011, 02:05 AM   #3
Motastic
Motastic's Avatar
Drives: E92 335!
I will have to try that. Its 2 am now, will give it a go in the morning
      05-13-2011, 06:43 PM   #4
Motastic
Motastic's Avatar
Drives: E92 335!
score that fixed my sunroof issue Thanks Now the AE issues what do yall say
      05-13-2011, 07:01 PM   #5
spdy330
spdy330's Avatar
Drives: 05 Tundra, 15 FIT, 17 CRV
^ That is awesome!
If you will be purchasing ANY AT&T services online or in store could you mention that you were referred by me? My Employee Referral ID is eo4489. This would be a great help and it costs you nothing, thank you!
      05-13-2011, 07:14 PM   #6
CasperSYTFU
SYTFU Crew
CasperSYTFU's Avatar
36
Drives: 2010 Toyota FJ
thats the cold test for angel eyes. let me get the code for you to stop the bulb tests for AEs.
Edit:
Disable the Cold Test for the Angels first and see if that stops it...
Code:
KALTUEBERWACHUNG_SL_V_L
     nicht_activ
KALTUEBERWACHUNG_SL_V_R
     nicht_activ
If it persists just go ahead and do the full AE error code out:
Code:
     nicht_activ
     nicht_activ
FEHLERMELDUNG_CC_SL_V_L
     nicht_activ
FEHLERMELDUNG_CC_SL_V_R
     nicht_activ
WARMUEBERWACHUNG_SL_V_L
     nicht_activ
WARMUEBERWACHUNG_SL_V_R
     nicht_activ
(all in the NFRM/FRM)
      05-13-2011, 09:24 PM   #7
charles.soori
23
Drives: 2016 F85 x5m
My AE and fog lights do that but it doesn't really bug me so i just left it alone.. since the AE is my drl as soon as i start the car it turn on..i only see my fogs do that
      05-14-2011, 03:27 PM   #8
1QuikWS6
No 55mph
1QuikWS6's Avatar
1616
Glad to help on the sunroof issue - good to see it worked
      05-14-2011, 04:27 PM   #9
CasperSYTFU
SYTFU Crew
36
Charles you can just code out the cold test on them and it will stop, and since you can leave the warm test functional, if they go out it will still throw a REAL error.
      05-14-2011, 11:18 PM   #10
charles.soori
23
It doesn't really bother me but ill give it shot tomorrow or whenever it stops raining here. Do you or anyone know which cold test is for the fogs?
Search this Thread:
Advanced Search
