Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Is it possbile to code the car, so it wont give bulb errors?
      05-12-2011, 06:55 AM   #1
zeroXTC
Drives: 320D - E90
Hi all!
If i buy a aftermarket HID kit and install it in my car, i will get errors on the dash. Is there anyway to code the car, not to give bulb errors?
Can i disable this feature?
Thanks!
      05-12-2011, 01:26 PM   #2
CasperSYTFU
SYTFU Crew
CasperSYTFU's Avatar
36
Drives: 2010 Toyota FJ
absolutely.
      05-12-2011, 01:46 PM   #3
zeroXTC
Drives: 320D - E90
Cheers!
Do you know the codes i should use? I guess it is in the FRM modul?
Originally Posted by CasperSYTFU View Post
absolutely.
      05-12-2011, 02:27 PM   #4
CasperSYTFU
SYTFU Crew
36
you're using them as your low beams? if so...
Code:
KALTUEBERWACHUNG_AL
    nicht_aktiv
WARMUEBERWACHUNG_AL
    nicht_aktiv
in NFRM (FRM)
      05-12-2011, 03:55 PM   #5
zeroXTC
Drives: 320D - E90
Hi yes! I will be using xenons as low and halogens as high beam.
Thank you for that!
      05-12-2011, 03:57 PM   #6
CasperSYTFU
SYTFU Crew
36
No problem man! Good luck, glad to help!
Search this Thread:
Advanced Search
