E93 Top Frozen! Helppppppppppp
05-09-2011, 04:35 PM | #1 |
45
Rep 598
So I'm putting my top down and it freezes. The three panels are stacked and hanging over the rear seat.
Key fob doesn't work Center console button doesn't work Putting key in door handle and attempting windows up/down procedure does not work Disconnecting battery for 35 minutes and reconnecting does not work Unplugging top controller wiring harnesses behind back seat and reconnecting does not work I am out of ideas. My SA is out of ideas. My dealer is an hour away on thruway and I don't want to drive it there as is... They told me the manual lowering procedure is extensive and difficult. He tells me it's like a 3 man job. Can anyone instruct me on how to do it? Thanks -Kevin Last edited by AMASIAN; 05-10-2011 at 01:46 PM.. |
05-09-2011, 04:42 PM | #3 |
45
Rep 598
I am under warranty.
The car drives. I don't really see a difference between having it towed and driving it. My concern is that the only two arms supporting all the weight of the roof will flex and this will happen regardless of the means it is used to get there. Also, Service department is closed so the car will sit outside when it arrives. The top is half down... |
05-09-2011, 04:45 PM | #5 |
205
Rep 2,770
Drives: E92 328i, E92 M3
This must suck SO bad... Garage it and pray it comes back to life while pursuing answers.
Maybe put thread in the regional forums and look for guys who can come and help you. |
05-09-2011, 04:46 PM | #6 |
MR x.
7
Rep 166
Drives: E93 335is DCT
is your car on?
05-09-2011, 04:49 PM | #7 | |
45
Rep 598
No, car is not on. I tried all of the above at every stage of ignition on to car running. Tried clearing codes. No success |
05-09-2011, 05:42 PM | #8 |
165
Rep 7,433
Is there any indication of it wanting to move? (Like do you hear the motor trying to move it?) Maybe a fuse?
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
05-09-2011, 05:47 PM | #10 |
8
Rep 135
Take pictures for your own record. So before you send it in, you know the condition it is.
Get your dealer to sort it going in, the roof can buckle with wind Force, then youve had it, you cant replace sections of the rook mech you have to replace whole thing, so dont take responsibility esp if its under warranty. Let your dealer collect and sort it... |
05-09-2011, 05:49 PM | #11 |
Roll Tide
591
Rep 2,345
Try fuse. Otherwise call the dealer. Express your flatbed concerns via email. If they decide to send a flatbed anyway, take a picture of it as it leaves your custody on the flatbed. The dealer will be responsible for any further damage caused by the wind.
Fix your broken/stripped cowl bolts with this elegant brass solution!
http://www.e90post.com/forums/showthread.php?p=20230306 |
05-09-2011, 06:35 PM | #12 |
Parrothead
137
Rep 1,232
Drives: E90 M3
wait your top is frozen and you are worried about your detail ... get the dealer to send a flatbed ... if you drive it they can claim you might have caused the issue
i would be more worried about my car then my paint quality and it being tarped or anything like that
|e46 M3 Stahlgrau/Red| - Sold |E92 335i BSM/Saddle| - Sold |e90 M3 Space Gray/Fox Red/6MT| See Garage for Mods |
05-09-2011, 06:50 PM | #13 | ||||
45
Rep 598
2007 Quote:
I'm hoping this gets sorted out easily and my hours are not wasted. I understand the priority of it all but from that comment, I'm going to assume you've never spent days with buffer in hand... |
05-09-2011, 06:52 PM | #14 |
866
Rep 5,451
I would probably go for the manual procedure if they will tell you how to do it. Curious how you disconnected the battery when you can't get in the trunk? If you disconnected it elsewhere, you may not have fully powered off the car. Also, if you can get the back seat to fold down, I would reach into the trunk and wiggle the luggage cover a bit in case it isn't fully engaged and stopping the top mechanism if it moved a bit when the top was in motion, otherwise, it could be one of many sensors that is failed. It sort of sounds like it quit moving right after the trunk lid closed and it thinks either the luggage thing has been moved or the the sensor's determining the trunk is closed have decided that it maybe ins't closed. Anything in your trunk right now that could have moved or gotten in the way anywhere?
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
05-09-2011, 07:03 PM | #15 |
Lucky13
212
Rep 1,762
I had mine do this a couple times and each time I accidentally put somethoing in the side area of the trunk. I put some duck tape there when I was trying to wire an antenna and it shut down the top about half way down and took we an hour to remember and look for the duck tape.
1995 325i, 1996 328ci, 1997 528i, 1997 Z3 2.8, 2000 528i, 2001 X5 3.0, 2001 330i Convertible, 2002 M3 Convertible, 2003 M3 Coupe, 2004 M3 Coupe, 2004 Z4 3.0, 2004 X3 3.0, 2007 X3 3.0, 2007 335i Convertible, 2013 X1 28 sdrive, 2014 M235 manual, 2020 X3 30i Xdrive
05-09-2011, 07:27 PM | #16 | ||
45
Rep 598
I will post pictures so you can see the position the mechanism is currently locked in. |
05-09-2011, 07:35 PM | #17 |
Parrothead
137
Rep 1,232
Drives: E90 M3
I actually do my own detailing and spend 3 days once a year prepping my car for the summer and two days prepping for the winter buffers in hand and all
but i have also owned a hard top convertible and i know the risk that is run by extended time when a top is stuck in a position that is not the service position, open, or closed it is a a lot of weight to be in a position it is not designed to sustain I hope you figure this out
05-09-2011, 08:49 PM | #19 |
this is the way
18157
Rep 8,527
You can get some of that cheap plastic painters tarp to put over it. It won't scratch or ruin anything and use some blue painting tape so it doesn't leave any residue on your car either.
05-09-2011, 09:12 PM | #21 |
NHTSA Nazi
28
Rep 1,983
Incorrect. Anything touching your paint will grind any dust or dirt on the paint into the paint. This gets worse when wind makes the plastic flap against the paint.
05-09-2011, 09:25 PM | #22 |
this is the way
18157
Rep 8,527
