NEED HELP
05-05-2011, 02:56 PM | #1 |
60
Rep 1,457
NEED HELP
last night when i was on my way home i mis shifted. instead of going from 5th to 6th i went to 5th to 2nd i know dumb causing the motor to rev over 8,000 rpms, BMW told me they wont cover it under warrenty, and told me i need a new engine costing me $16000. is there anything that i can do, ive contacted BMWNA as well and they said the same thing that its not covered because of user error
if anyone has any advice or someone they know i can talk to, to help me resolve this or if they are BSing me please let me kn thanks Petrovic |
05-05-2011, 02:58 PM | #2 |
153
Rep 3,730
Money shift! That is true what they told you.
Better call your insurance company if you really do need a new engine. Was there actual damage to the engine or did you just wreck the transmission?
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
05-05-2011, 03:09 PM | #4 |
60
Rep 1,457
My insurance company will cover a new engine? tranny is fine its the engine
05-05-2011, 03:10 PM | #5 |
60
Rep 1,457
05-05-2011, 03:12 PM | #6 |
ghey
483
Rep 2,041
You can ask your insurance but they probably won't cover it
Not to sound rude but it comes down to driver error or negligence. The vehicle cannot prevent overrev issues when it's mechanically forced to do so; if you had revved up to redline it would limit you and cut off fuel, but you physically forced the engine to go that fast, at which point timing is off and you fuck up valves and pistons etc. I wouldn't imagine you need an entirely new engine, but i'm sure you've got major problems. Valves, head, piston, etc.. but it's not like every component of the engine just stops working because of an over rev.
21 G05 > 20 G05 > 17 G30 > 14 F30 > 08 E90
05-05-2011, 03:19 PM | #7 | |
60
Rep 1,457
05-05-2011, 03:37 PM | #11 |
One cam is enough
130
Rep 6,801
Ahhh... The money shift.
That sucks. If it makes you feel better, there are money shift stories littered all over BMW forums (as well as other manufacturers I'd assume) for years back..... That sucks man. There's not much you can do besides fix it, but a money shift will for sure have wrecked the shit out of the inside of your engine. There's no easy way around it. Best of luck though, let us know how it turns out. |
05-05-2011, 03:38 PM | #12 |
Knower of all Things Useless
29
Rep 254
It might be worth trying to give your insurance a call. I blew up my motor in my Jetta and they actually covered me buying a used motor as well as the labor to install. I could install on my own, so I bought a new crate motor with upgraded internals and it ran better than it ever had.
It's always worth a call to see what they may be able to do for you. |
05-05-2011, 03:44 PM | #13 | ||
60
Rep 1,457
05-05-2011, 04:13 PM | #15 |
60
Rep 1,457
05-05-2011, 06:13 PM | #16 |
124
Rep 2,554
I wanted a manual for my next car. 16,000 dollars for one wrong down shift... Count me out! Lol
05-05-2011, 06:25 PM | #17 |
60
Rep 1,457
05-05-2011, 06:29 PM | #18 |
64
Rep 338
Just curious
how did it go down? Did you downshift and then BAM! Was there a noise? smoke ? engine lights ? immediate need for new underwear? Does it turn over really fast now? Take it to an Indy and have them perform a cylinder leakdown test Did you look in your oil fill cap for shrapnel? |
05-05-2011, 07:33 PM | #20 | |
60
Rep 1,457
Tischers??? never heard of them, but ill take a look thanks a lot |
05-05-2011, 07:39 PM | #21 |
Nate Dogg
8
Rep 437
Man that sucks. I don't quite understand how you went that far in the gearing. You must have forced it into second. Your insurance will probably cover the engine if it is stock. I blew an engine while spraying on a Chevy truck and my insurance company replaced the engine (I made sure to remove the nitrous and everything off of it before they saw it).
-Nate
2011 BMW 328i by weekend, various airplanes by week.
05-05-2011, 07:41 PM | #22 |
Grozniy
177
Rep 2,602
getbmwparts.com aka Tischer
As someone else mentioned buy a used engine off eBay http://cgi.ebay.com/ebaymotors/BMW-E...Q5fAccessories
-fatman
