05-04-2011, 11:49 AM | #1 |
Enthusiast
54
Rep 20
Need help with SQL query. Any IS people please help.
I'm making a database in Access for a ficticious company for my final project in my Business Database class. The query needs to sum the PayableAmount in the Claims table for each employee then subtract it from the MaxAnnBenAmt in the Plans table thats related to employee. The Employee has a status which corisponds with ClassElidgability for each plan.
The query i have written so far that gives a syntax error is: SELECT Claims.EmployeeId, SUM((SUM(Claims.PayableAmount)) - (SUM(Plans.MaxAnnBenAmt)) FROM Employees INNER JOIN Claims on Employees.EmployeeId = Claims.EmployeeId INNER JOIN Plans on Claims.PlanName = Plans.PlanName GROUP BY Claims.EmployeeId Here is the ERD for the database: Just saw the ERD is not up to date. Claims also has EmployeeID as a FK, DateofService, and PlanName as a FK.
"Life is risky business" ~Schirmnov, Oleg
05-04-2011, 11:57 AM | #2 |
113
Rep 1,311
Drives: 2009 M-Sport 135i
I think you need to give the sum function/column a name.
So try something like: SELECT Claims.EmployeeId, (SUM((SUM(Claims.PayableAmount)) - (SUM(Plans.MaxAnnBenAmt))) net_payable and you might have to add the "net_payable" column to the group by |
05-04-2011, 12:00 PM | #4 |
181
Rep 962
so specifically:
SELECT Claims.EmployeeId, SUM(Claims.PayableAmount) - SUM(Plans.MaxAnnBenAmt) FROM Employees INNER JOIN Claims on Employees.EmployeeId = Claims.EmployeeId INNER JOIN Plans on Claims.PlanName = Plans.PlanName GROUP BY Claims.EmployeeId |
05-04-2011, 12:03 PM | #5 |
113
Rep 1,311
but doesnt it still need a name, i think thats where the syntax error is coming in
05-04-2011, 12:04 PM | #6 | |
181
Rep 962
I also have no idea how the Access handles bad errors, but you can't do sums on sums, so that could be getting read out as a 'syntax' error |
05-04-2011, 12:07 PM | #7 |
113
Rep 1,311
Cuz when I write query in SQL Server, it will cause a syntax error if there is no name. maybe its different when writing SQL in access
05-04-2011, 12:09 PM | #8 | |
181
Rep 962
I just ran this: select sum (fe_charmax)+ SUM(fe_data_type) from tblfields group by fe_id With no problems |
05-04-2011, 12:13 PM | #9 |
113
Rep 1,311
I'm using SQL Server 2008. I just tried removing the names of a sum function and it didnt run saying "No column name was specified" and when I added the name it ran
05-04-2011, 12:13 PM | #10 |
154
Rep 4,528
Drives: M2 CS
havent done SQL in forever but this looks right to me
05-04-2011, 12:15 PM | #11 | |
181
Rep 962
You're saying you get an error if you do something as stupid as: select SUM(1+1) from sys.all_views ? Well OP, your initial issue is definitely the sums of sums. secondary might be the naming convention. between the 2 you should be golden |
05-04-2011, 12:18 PM | #12 | |
113
Rep 1,311
05-04-2011, 12:21 PM | #13 |
181
Rep 962
05-04-2011, 12:23 PM | #14 |
113
Rep 1,311
It was just a sum of two columns. Maybe its something to do with the tables in the databases here at work.
05-04-2011, 12:24 PM | #15 |
181
Rep 962
05-04-2011, 12:34 PM | #16 |
113
Rep 1,311
05-04-2011, 12:43 PM | #17 | |
181
Rep 962
It has to be a setting somewhere. regardless it's bad practice to not have an alias |
05-04-2011, 12:45 PM | #18 |
113
Rep 1,311
yeah, i would put names anyways cuz it makes it much cleaner and easier to work with
05-04-2011, 12:47 PM | #19 |
181
Rep 962
hell in it's current state I don't think it'd even be useable by access (or anything). when it DOES run in sql for me, it has no column name. Thus there's no way to reference it.... I'm hoping the OP already thought about that
05-04-2011, 12:53 PM | #20 |
113
Rep 1,311
Exactly. That's why i put names anyways. I hate having columns with no names.
05-04-2011, 12:54 PM | #21 |
Enthusiast
54
Rep 20
Thanks for the help guys. I finally got it to work.
SQL code was: SELECT Claims.EmployeeID, Plans.ClassEligibility, SUM((Plans.MaxAnnBenAmt) - (Claims.PayableAmount)) AS Remaining_Benefit FROM (Employers INNER JOIN (Employees INNER JOIN Claims ON Employees.EmployeeID = Claims.EmployeeID) ON Employers.EmployerID = Employees.EmployerID) INNER JOIN Plans ON (Plans.PlanName = Claims.PlanName) AND (Employers.EmployerID = Plans.EmployerID) GROUP BY Claims.EmployeeID, Plans.ClassEligibility;
