FUCHs motor oil
04-26-2011, 11:15 PM | #1 |
16
Rep 263
FUCHs motor oil
Sorry this may have been covered before but just wanted to confirm that FUCHs is an approved oil for BMWs?
Those who has used this, comments welcomed. |
04-27-2011, 09:59 AM | #2 |
74
Rep 1,543
04-27-2011, 11:13 AM | #3 |
3575
Rep 10,355
04-27-2011, 01:08 PM | #5 |
74
Rep 1,543
The weight of the oil is negligable here, after all total, motul and several companies make BMW LL01 approved 10W-50. so NO, that doesn't answer my question. BMW's LL test must be performed on all oils, before they are used in BMW engines. This is your idea. Now please defend that stance where we see E46 M3/E90 M3/M5's/Z4M's etc.... not using BMW LL tested oils. Don't give me that its an M, because its BMW relabelled castrol 10W-60 used in these cars. So why doesn't castrol do the BMW LL test on this oil, like it does for some of its products?
04-27-2011, 01:54 PM | #6 |
74
Rep 1,543
Well, I could simply say, if BMW LL-01 testing is not required for anything higher than a 0W-40, why then did they perform it on Total, and Motul's 10W-50? But that would just be falling into your trap, and dodging the issue.
First you are completely ignorant about what the LL-01 testing sequence involves. You instead list tests done by the ACEA, which is not what the LL-01 sequence includes. Here is what the BMW LL-01 is: "BMW LL-01 - Like the LL-98, also required to be ACEA A3, API SJ, and run a 370 hour test, but the test engine is now an M54 and compatibility with the valvetronic system is a specific test requirement. These oils tend to run a little bit lighter than the LL-98, with a Kvis100 range of 11.3 to 14.1, averaging about 12.3. HTHS averages about 3.6, TBN about 10.4, and density about 0.849." So maybe running an oil in an M54 (2001 BMW 330CI) engine cannot ensure it will last in an E46 M3 engine (S54), or even a 335I engine (N54)? |
04-27-2011, 04:15 PM | #7 | |
16
Rep 263
I just noticed that it's very hard to type Fuchs without mis-typing the other F word instead. |
04-27-2011, 05:59 PM | #8 | |
3575
Rep 10,355
04-28-2011, 05:58 PM | #9 | |
486
Rep 1,614
The biggest question is which oils will be available over here. You might have better luck with Canadian suppliers. Let us know what you choose, and where you get it! P.S. Fuchs have introduced a new additive package call "XTL Technology". I haven't been able to find specs for these oils so far. |
