BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - Mid-Atlantic > Sheesh! Anyone have Wurth Silver Paint?
      03-20-2007, 03:24 PM   #1
BK
Smiling politely
Drives: 330i
2006 330i  [9.00]
So I finally decide to DIY repair the curb rash on my 162s, and I started shopping for what I need. Most important is the Wurth German Alloy Silver Wheel Lacquer paint, which matches the silver for our alloy wheels.
Unfortunately, it is OUT OF STOCK EVERYWHERE. :mad: Apparently, Wurth issued a nation-wide recall on this item in October 2006 because the nozzle gets clogged easily, and it still is not stocked anywhere. See http://classic-motoring.stores.yahoo...usilasppa.html for example (see the note at the bottom of the page).
Does anyone in the DC area have any of this paint from the pre-recall days? I will buy it from you, and I can drive anywhere in the area to pick it up.
E90 330i Black Sapphire 6MT | 991.1 C4 Platinum Silver 7MT
      03-20-2007, 04:36 PM   #2
ase2dais
//Mdicted
ase2dais's Avatar
Drives: a Cop Magnet
you may want to PM SteveMD, he repaired his wheel and have kept hi PM to me for future reference. He may still have a few paint left, or know another source. Good luck
Originally Posted by SteveMD
Hey there. The WURTH paint is here: http://www.superiorcarcare.net/tirewheelcare.html
You can get Bondo brand red putty at any Pep Boys or similar store.
You also need sanding primer - about $4.
For sanding, I used 400 grit to initially clean up the scratch. Then put the bondo on to fill in the scratch. I then used 800 with water to sand down the bondo.
The wheel should now be the right shape.
Tape up the wheel - I covered the tire only since I wanted no masking lines. And obviously the paint. I actually covered the whole car with the car cover from my Corvette.
Carefully apply the primer - just a few passes will work. Immediately use thinners to remove overspray from your wheel.
Give it a couple of hours.
Wet sand again with 800. You should be now ready to apply the Wurth silver. Again, just a couple of passes should do. Wipe off excess.
Let it dry for at least 12 hours. Then apply another coat. 12 hours. Then apply the clear.
That's it. I then used 2000 grit to 'polish it up' along with some liquid polish.
Good luck.
      03-20-2007, 05:12 PM   #3
SMOKE EM IF U GOT EM!!
SMOKE EM IF U GOT EM!!'s Avatar
Drives: 06' E90 330, 20' F97 X3m
2006 330i SPORT  [7.34]
i ordered my cans from autotopia.com pretty cheap i thought!
LIVE FAST..DRIVE FASTER!!
      03-20-2007, 05:16 PM   #4
BK
Smiling politely
Drives: 330i
2006 330i  [9.00]
You mean www.autopia-carcare.com, and they don't have it in stock, either. Adding it to your cart gives you the following message, presumably because of the recall: "The Wurth German Alloy Silver Wheel Lacquer is not currently available. Please contact us for availability of this item."
Would you be interested in selling your partially used paint? Seriously, I don't need much.
      03-20-2007, 05:19 PM   #5
yeah thats it. lol sorry. havent bought much from them, just the paint, which i dont have any more of. sorry again!
      03-20-2007, 09:48 PM   #6
BK
Smiling politely
Drives: 330i
2006 330i  [9.00]
Ah ha -- so this place says "out of stock until 4/1/07." I can live with that, assuming they'll actually get it in stock then:
http://www.goodspeedmotoring.com/?pa...el%20Paint
If anyone in the DC area has any they'd be willing to part with in the meantime, though, I'd love to get my 162s done earlier rather than later.
      03-22-2007, 02:51 AM   #7
kepford
kepford's Avatar
Drives: Badly
Has anyone found a paint that matches as well as the Wurth paint? I tried my TIAG touch up paint and its close but not an exact match. I contacted several online auto shops and nobody knows if they will actually be getting Wurth silver back in stock. It's summer rim time and I'd like to get mine looking the best they can.
      03-22-2007, 04:40 PM   #8
BK
Smiling politely
Drives: 330i
2006 330i  [9.00]
They advertise Einszett (1Z) Silber paint as a match for Wurth Silver Metallic, but I've read some posts that say the 1Z is a shade darker and does not match well.
Here's the 1Z: http://www.pelicanparts.com/catalog/...g10.htm#item45
      03-22-2007, 10:43 PM   #9
kepford
kepford's Avatar
Drives: Badly
Thanks for the link. I'm going to wait until the second week of April to see if anyone actually hears if they're going to get the Wurth back in stock. If not I may have to take a chance on the Einszett.
      04-02-2007, 08:26 AM   #10
PSUBALL10
PSUBALL10's Avatar
25
Drives: 2018 X5
http://www.goodspeedmotoring.com/?pa...=Wheel%20Paint
Now they r saying out of stock until 7/1/07
      04-02-2007, 08:32 AM   #11
BK
Smiling politely
Drives: 330i
2006 330i  [9.00]
I ended up buying the Dupli-Color Silver Wheel Paint. I have not used it yet, but Josh49 claims a close match to the OEM wheel paint. You can find this paint in most Auto-Zone or Pep Boys stores.
Based on my schedule, I may not be able to get to my wheels until the week after Easter.
See this thread: http://www.e90post.com/forums/showth...590#post801590
EDIT: I've spent some time Googling "Wurth Einszett silver wheel paint" and variations on that theme, and I've found a few interesting threads. I was toying with the idea of Einszett, but I have read more threads that says it's a little darker than the OEM shade. Another interesting thing I found is that the Wurth silver flakes apparently are a slightly different size than BMW OEM, so it is not an "exact" match, but it's very very close. I plan to stick with the Dupli-Color for now until the Wurth is available again.
http://mye28.com/viewtopic.php?t=251...2729ae224e417f
      04-02-2007, 05:07 PM   #12
PSUBALL10
PSUBALL10's Avatar
25
Drives: 2018 X5
BK please keep us updated on how that turns out. The mark on my wheel isnt that bad, but i wanted to try and touch it up before i put them on.
      04-02-2007, 05:12 PM   #13
shimshimhada
shimshimhada's Avatar
Drives: Portal
Rofl, I have a brand new can of Wurth Silver and Wurth Clear. Somehow I missed this thread.
      04-02-2007, 05:22 PM   #14
BK
Smiling politely
Drives: 330i
2006 330i  [9.00]
Shim, any interest in selling it? Although I would not be surprised if you have one of the defective cans that clogs up (I've read "every can I tried was unusable within three seconds").
      04-02-2007, 05:26 PM   #15
shimshimhada
Drives: Portal
Well, I wanted to fix one of my wheels eventually, but never got around to doing it. I guess I could sell it to you. I'm not sure when I bought it, it was a while back. Do you know which batch is defective?
      04-02-2007, 09:32 PM   #16
BK
Smiling politely
Drives: 330i
2006 330i  [9.00]
They began the recall in October last year, but I saw posts from July where someone reported having lots of trouble with the paint. So maybe July 2006 or so, at the latest, and probably cans from earlier than that. I guess they still haven't fixed the problem. See this thread: http://forums.bimmerforums.com/forum...d.php?t=560220
"wurth is [bleep], i recently painted my wheels and recieved 3 or 4 defective cans. get Einszett Sibler Spray from pelican parts, the match is pretty good, no complaints here." (July 6, 2006)
Still, if you'd be willing to sell it, I'll not only pay full price for the can, but I'll buy you a new can once they start selling it again (as PSUBALL10 said, the expected date is now July 1st). If it clogs on me, I'll just use the Dupli-Color and I'll be ordering myself a new can once they sell it, anyway. PM me and let me know. On the other hand, if you want to hold onto the can, I understand and I'll just go with the Dupli-Color for now.
      04-02-2007, 10:34 PM   #17
shimshimhada
Drives: Portal
I checked my invoice, I bought the can in August 2006, so I don't know. I'll just give you my can since I probably won't get around to it anytime soon, and you can buy me one whenever they restock it. You don't have to pay two-fold for a can that might clog.
      04-02-2007, 11:10 PM   #18
BK
Smiling politely
Drives: 330i
2006 330i  [9.00]
shim, you're the best. I'll PM you. I can drop by anytime this week to pick it up, if you're around.
      04-03-2007, 02:19 PM   #19
bavarian19
bavarian19's Avatar
Drives: Car
Brian...
I have a ding on one of my 189's... I might be doing the wheel repair as well... Let me know how it goes because I might not be too far behind you in doing the repair...
      04-03-2007, 03:19 PM   #20
BK
Smiling politely
Drives: 330i
2006 330i  [9.00]
No problem, AJ.
      04-04-2007, 08:29 AM   #21
ase2dais
//Mdicted
ase2dais's Avatar
looks like a good Meetup Group DIY
j/k
      04-05-2007, 09:32 AM   #22
bavarian19
bavarian19's Avatar
Drives: Car
j/k
I would be all about it, but Im in sunny San Diego as we speak... Wont be home until Sunday, and I know Brian was talking about doing this relatively soon...
