2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions Whiteline tail lights installation
      04-20-2011, 06:47 AM   #1
turole
Drives: 335i
Hi,
is there any DIY guide for installing the whiteline lights? Thanks already in advance for your help!
      11-26-2011, 08:18 PM   #2
st8800
Drives: F10
I'm getting my white lights soon too... anyone can chime in?
      11-27-2011, 09:39 AM   #3
grimlock
716
Drives: F10 N52B30@255PS
Remove the pins holding the trunk trim, middle and sides, only the part allowing you to reach inside to get to the lights. Its quite a logical progression, not hard at all for beginner.
But you need a 8mm long drive socket, for the middle lights. The others are reachable with normal adjustable wrench.
Unplug and replug.
Quite simple, just need the 8mm long drive or you'll be stuck.
      05-31-2012, 10:04 PM   #4
rikuF10
Hong Kong
81
Drives: F10 G29
2019 BMW Z4  [0.00]
2012 BMW 528i  [8.50]
Unplug and replug.
To remove the trunk lid trim, do you know what is the the scew type/size that is holding it? need to go buy a new screwdriver.....thanks!
      06-01-2012, 12:26 PM   #5
GIANITALY
GIANITALY's Avatar
Spain
38
Drives: 2016 X6 M/MPPK
  [0.00]
I Just Change Mine Yesterday And It Was Very Easy. They Are Not Screws , Look Like Them But They Are Plastic Ones That Snap In And Split Inside So First You Need To Do Is Get A Pliers And Pull The Screw Out And Then pull it all together.
2016 X6 M PACK/MPPK
RACECHIP BLACK GTS
RACECHIP XLR
      07-12-2014, 09:38 AM   #6
swksuwc57
Drives: 2012 & 2014 BMW 550i
I found this in case someone is looking
I found this in case someone is looking to replace tail lights Here u go:
BMW_F10_White_Line_TailLights.pdf>
      07-23-2014, 05:57 PM   #7
swksuwc57
Just put them on my car..had multiple compliments already..easy install.
      07-30-2014, 05:50 AM   #8
fung0001
17
Drives: f10 2013 520i Hartge Tuning
not as simple as originally thought
my garage took over 30 min to complete with 2 persons working!
      07-30-2014, 05:53 AM   #9
fung0001
17
it also needs to test if all the light functions remain intact
5post
