BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > Vishnu Procede n55 dyno with prototype FMIC (360+WHP)
Closed Thread
      04-18-2011, 04:36 PM   #1
OpenFlash
Drives: A Lot
Exclamation Vishnu Procede n55 dyno with prototype FMIC (360+WHP)
Hi guys,
Been a busy last few weeks. Today we tested the prototype FMIC we've developed for the n55. Tried a couple a couple different FMIC designs before settling on this one. It works the way we want it to and seems to be perfectly matched to the stock turbo. Better cooling but without excessive volume (no extra lag). And not excessively heavy (less of a heat sink). We plan to go into production with it after we get caught up with other things. No ETA yet. No pics to disclose. But the results were very promising. The Procede map was a slightly tweaked version of the 3-21 maps that are currently available for download. Tweaks involved small changes to the IAT compensations and ignition timing maps.
Car info:
N55 135 w/7DTC
91oct
Vishnu Procede v5
Vishnu DP
Vishnu Large charge pipe
Cat-back
Stock FMIC vs. Vishnu Proto FMIC:
Same dyno with nearly identical conditions
Boost setting at 15psi, IC at 50%
Below is a video of a 15psi run. You can watch the boost gauge on the dash (fuel gauge) during the run. It peaks just shy of 15psi in the midrange and falls to 10-11psi up top. Pretty low boost for 360+whp. The n55 is an excellent engine. Better than the n54 in many respects i'd say. And a properly matched FMIC upgrade was worth 20-30whp gains from 4200 to 6500rpm!
We also did a few runs at a lower peak boost setting (just 12psi). Lost quite a bit of low end/midrange torque. But only down 6-7hp peak. In fact, it made slightly more power way up top no doubt because IATs were slightly lower (from running less boost down low).
15psi peak vs. 12psi peak:
      04-18-2011, 05:24 PM   #2
Bluesummer
Bluesummer's Avatar
Taiwan
588
Drives: slower than Ayrton Senna
2017 BMW X5M  [0.00]
2015 M4  [0.00]
2011 E82 135  [0.00]
2011 M3  [0.00]
2007 335  [0.00]
oh wow
IG:d.violet.m3
      04-18-2011, 05:29 PM   #3
EastBayE90
Formerly (-(ellblazer420
EastBayE90's Avatar
Drives: 07 E90 335i M/T, 15 F80 M3 DCT
Torque monster!!!! Good stuff Shiv
(410whp 445ft/lbs | DCI + Meth Only)
OpenFlash OTS Stage 1 Flash | Vishnu PWM Meth Kit | Vishnu DCI| Forge DVs
      04-18-2011, 05:52 PM   #4
Transport3r
Transport3r's Avatar
86
Drives: 2011 N55 E90
What is all this not working on the fuel system/meth kit nonsense?
Get back to the real work
Nice numbers though, and holy fan setup! that beats the asthmatic wimpy thing I had when I dyno'd!
Josh-
      04-18-2011, 06:06 PM   #5
FrankiE90
FrankiE90's Avatar
Drives: Krooked Sk8board
those numbers look very good at 15psi.
have u taken'n it to the track with that setup?
i'm happy with the boost setting at 12psi - numbers look
great with the FMIC - shoot, but if settings at 15psi are
consistent on the track - i'm jezzing.
i'm dye'n over here waiting on a couple of tunes.
i have a fmic just sitting here ready to be slap'd on.
oh well, whenever you guys are ready.
FrankiE90 AKA:.[The TANK] *CLICK THE SIG
E90s (been gone but not forgotten) • KW clubsports • • • • • • • • • • 18" BBS GT4 // Build E30 (pending) + E46 M3 Wagon ESTORIL Blue
      04-18-2011, 06:12 PM   #6
makarov88
12
Drives: N55 335i M-Sport
Shiv I'm curious, the last Dyno you posted under the 15 PSI pulls you had something like 425 TQ, why did it drop after upgrading the charge pipe and FMIC although granted your HP numbers went up a bit?
      04-18-2011, 06:13 PM   #7
Clap135
Clap135's Avatar
102
Drives: 2009 N54
car to discuss why the n55 is better then the n54? Curious to hear your reasoning
      04-18-2011, 06:16 PM   #8
OpenFlash
Drives: A Lot
The first cold runs always seem to have the highest torque numbers. But they are usually just short-term low end spikes. Pretty useless as far as performance goes. When actually conducting testing/comparions, I always use hot runs with just 2-3 minutes of cooldown between pulls. They don't always give the best numbers but they are far more realistic and stable.
Shiv
      04-18-2011, 06:19 PM   #9
e92sport
38
Drives: black e92 sport
Are these maps going to be available for download?
Did you go with a stepped core fmic?
      04-18-2011, 07:01 PM   #10
IancoleTX
Dillo boxers
IancoleTX's Avatar
Drives: 2019 M5C
Damn son
2019 M5C Matte MBB / Tartufo
      04-18-2011, 07:03 PM   #11
onesuperboi
onesuperboi's Avatar
Drives: '08 e92 335i COBB 4.01 Stage 1
+1
      04-18-2011, 07:08 PM   #12
Pepe_pr
Puerto Rico
35
Drives: 135i black on black
I will be happy to test the new maps since i have fmic
Need a testmule?
USED TO HAVE A 385 whp 479 tq N55 335 2011 (AT) AND NOW A 135 M package 2010 (AT) 447whp/504tq
      04-18-2011, 07:49 PM   #13
Keik E92 M3
Drives: BMW M3 DCT
2009 BMW  [9.00]
2011 BMW 335i  [6.80]
HELLA NICE!!!
      04-18-2011, 09:40 PM   #14
BMW1986
BMW1986's Avatar
Drives: 11 M3 E92 ZCP JB/PS & BLK
Shiv, no thoughts on making a FMIC or DP's for the N54? I know Rob said the market is "flooded" but I know if you designed something people would buy it based because of your reputation rather then people making something simply for $$$$.
11 E92 M3 DCT Jerez Black ZCP...Eisenmann, Dinan, Fabspeed, IND, LUX
      04-18-2011, 09:52 PM   #15
grandmoff
Drives: 2011 e92 335i M-Sport 6MT
good stuff Shiv!
      04-19-2011, 11:10 AM   #16
Pepe_pr
Puerto Rico
35
sex
      04-19-2011, 11:26 AM   #17
David1
David1's Avatar
812
Drives: 09 E92 09 X5
Shiv, Will the IC use stock connectors?
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
      04-19-2011, 11:46 AM   #18
stealth-twntrbo
stealth-twntrbo's Avatar
Drives: 2020 740xi
Big single N 55 any time soon?
      04-19-2011, 12:06 PM   #19
htt760
PROcede it and Call it a DAY
Drives: 2011 135i DCT, 2011 335i
Dammmmmm... that thing makes great horsepower on the car!
      04-19-2011, 12:08 PM   #20
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
Intercooler is just what the doctor ordered
      04-19-2011, 12:19 PM   #21
dzenno
271
Drives:
Shiv,
The N55 being in many ways better than the N54, any details?
I've read details on their head design and know that in stock form it has somewhat higher VE..what else?
      04-19-2011, 01:36 PM   #22
OpenFlash
Drives: A Lot
Originally Posted by dzenno View Post
Shiv,
Yes that's where the n55 seems to have a sizeable advantage. Power power at a lower boost pressure all things equal. Suggests that the head flows better (less boost accumulated at the manifold). There is also far less pumping loss during non-WOT conditions (no manifold vacuum) which means smoother engine performance. And you can feel it. Especially during transitions from partial to full load. I can't wait to see what this engine will do with an upgraded single turbo. Wouldn't be surprised if it made 450whp at just 15psi from GT30R or something comparable.
Closed Thread
Tags
best intercooler, best tune, procede
