xi vs. i while moving
04-16-2011, 10:02 AM | #1 |
84
Rep 703
people say that the xi will launch better because of better traction but once the two are moving the i pulls away. the reason for this is because the xi has to put power to all four wheels accorind to people. but i thought the xi only puts power to the front wheels when it feels them slipping? so i could see the i start to pull away because its lighter but i dont get the whole power to all four wheels thing? and how much faster is the i once the two are at like highway speed? thanks
04-16-2011, 10:10 AM | #2 |
FREE DREAMK
162
Rep 9,321
Drives: the shiiit!
Yes
04-16-2011, 10:11 AM | #3 |
ghey
484
Rep 2,041
There is a bias towards the rear on the xi, but the front wheels will always be getting some power I believe. Not sure what the standard f/r power ratio is.
The xi jumps off the line with all 4 wheels under power, and it's hard to slip/burn all four tires, so the car just launches [we have a V8 fulltime 4WD vRunner and it's fun to stomp it, just leaps forward]. Once you're up to speed I don't think it's going to provide any straight line 'racing' advantage, and you do have some drivetrain powerloss because of the additional components and a slightly heavier car.
21 G05 > 20 G05 > 17 G30 > 14 F30 > 08 E90
04-16-2011, 10:13 AM | #4 |
40
Rep 957
power has to be distributed from the motor through the drivetrain components, through the axels and finally to the wheels. you lose power along this travel. two wheel drive cars will lose approx 18% while AWD, much more obviously.. the I will slowly pull and pull on the xi stock for stock. this is why tuned 335i's are just as fast as the Audi R8 (v8 model)... AWD drivetrain loss not to mention the quattro system is heavy...could you run with your legs alone or faster applying weight to all four limbs galloping like a gorilla?? exactly. ok JK That not similar at all.
04-16-2011, 02:59 PM | #6 |
84
Rep 703
ok so the i would start to slowly pull away stock vs. stock. but lets say the i is stock and the xi has a jb3 on say map 1 then would they be equal or would the xi pull away or is that still not enough for the xi to beat the i?
04-16-2011, 03:01 PM | #7 |
348
Rep 1,237
Dont think it would be a drastic difference. Def a lot more drivetrain loss and heavier- but from a dig tey might just be half a car apart since the xi has the jump on the i
04-16-2011, 03:24 PM | #8 |
596
Rep 3,386
i dont think the OP is asking who would win in a race from a dig up to like 150mph. he is asking if both cars start at 60mph and go to 150mph how far ahead would the i be. and how much extra power the xi would need to stay next to it. i'd say map 1 on the jb3 in the xi with 11psi instead of 8.8psi would be more then enough to compensate and the xi would win. someone else chime in if i'm wrong.
04-16-2011, 03:39 PM | #9 |
40
Rep 957
oh god yes. haha. jb3 is boosting your hp figures by like 80hp crank lol. that's more than enough. a jb3'd xi would be much faster than a stock i yes sir.
04-16-2011, 10:13 PM | #15 |
165
Rep 2,875
Yea it would.....diff between 8 psi and 11 psi is roughly 30 hp.
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
04-16-2011, 11:07 PM | #16 |
Jerry's Fault...
175
Rep 9,258
The "i" is not an "almighty monster" vs the "xi"... Are you kidding me? a tuned jb3 (xi) vs a stock (i) is no comparison.....
Boopie*Motorwerks Martino*Auto*Concepts |
04-18-2011, 09:12 AM | #19 |
24
Rep 1,190
How is 100 percent of the power sent to each axle? Anyone ever look into the way the xdrive system distributes power?
2011 VW GTI 4dr-6mt-Sunroof-Nav-Xenons
OLD: 08 335i AW/CR/Poplar 6mt-ZSP-ZPP-ZCW-iPod-iDrive-PDC-Style 230s w/FK 452-Dinan LSD |
04-18-2011, 06:15 PM | #20 |
10
Rep 270
04-18-2011, 07:57 PM | #22 | |
24
Rep 1,190
The X-Drive system CANNOT send 100 percent of engine power to the front wheels. If both rear wheels lose traction then it can technically be considered 100% power to the front wheels because the rear wheels aren't doing anything. I've been over the design of the x-drive t-case and there is just no logical way to divert 100 percent power to the front axle.
